    Results 1 to 10 of 10
      Feb 2014
      Country Flag: Mexico
      installing passenger side control arms
      Any else had trouble installing the passenger side lower control arm its from global west and for a 1st gen f body..doesnt want to go inside the slots to bolt them up driver side was easy to do
      It often happens that the tabs that hold the control arms get smushed when the control arms are tightened, especially with rubber bushings. Take a soft mallet and open up the openings a little.
      Jul 2007
      Or, you could make one of these simple tools and spread the opening(s) until the control arm fits...
      Name:  Control Arm Installation  Tool.jpg
      BE different....ACT normal.
      No one is completely useless..They can always be used as a bad example
      Lawrenceburg, TN
      its forty year old steel, it has to be persuaded, pry bars, rubber mallets...remember its says bolt in, its not.....you have to help it along
      Feb 2014
      Thanks will do...how u make that tool
      Jul 2007
      Quote Originally Posted by 69firebird19 View Post
      I haven't made one yet... I think Camaro control arm bolts are 5/8". Get a 5/8" stud or bolt and cut it down to about 1" or so longer than the gap in the frame. Get 2 nuts and 2 washers (5/8) as well. I'd use grade 8 hardware for this tool, and make sure you lightly oil the stud/bolt.
      Aug 2011
      Connecticut
      I would use a piece of threaded rod and two nuts to spread it. . . No im just kidding id probably smack it a couple few times with a mallet.
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
      Sep 2001
      Accord, NY
      That's what I did. Easy job! Good luck!
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Feb 2014
      Hope its easy i havent tried to smack it since i havent had time to work on the car
      Jul 2007
      I'd probably use the stud and nut spreader tool. You could use a big rock if you like... To each their own.
