View Full Version : For Sale - Parts
- Brand New LT4 Crate Engine
- Speedtech Extreme Subframe *New*
- Camaro part out LS3, T56, RideTech, Wilwood, Forgeline, Subframe 4 link, 12 bolt
- !st Gen RingBrothers handles - Black
- Refurbished 67 Chevelle Guage Cluster
- Detroit Speed RS Headlight Kit 122004 for 1968 Camaro
- Dynabrade 6in da sander
- Gen 4 LS PSI Harness with computer, pedal, o2 sensors, mounting bracket
- 1969 Camaro valance custom all metal.
- TKX Crossmember F body
- LSA/LS9 Intercooler Fluid Pump
- 1967-69 Camaro/Firebird OEM Subframe with RideTech Suspension
- Tremec TKO 600 5th gear .82 conversion
- 67-69 camaro SPC upper control arms
- K5 blazer front, rear, and door panels black houndstooth upholstery! $4,700
- MSD coils (NEW) Harness and
- Fiske 3 piece wheels
- Coys 17x8 wheels + track tires
- 1970 Camaro Ls swap headers
- GM G body RideTech upper A arms
- Detroit Speed DSE Mustang Aluma-Frame take off's
- (So Cal) 67-68 F-body fuel tank w/ Holley 350lph drop in fuel pump
- RacePak IQ3
- Eddie Motorsports Trunk Hinges 67-69 Camaro
- new Ridetech 4-Link and Currie 9" Rearend 67-69 Camaro / Firebird
- Holley Teminator x kit SBC
- Brand New Forgeline SP3P Wheels with Michelin Pilot Sport 4S Tires Used For Mock Up
- Forgeline GZ3 Wheels with BFG Rival Tires – 5x4.75 Bolt Pattern
- 1969 Camaro LS Swap Radiator
- Marques 1969 Camaro RS lights New
- Holley 20-137 high mount accs kit ls/Lt, short spacer kit, and edelbrock 8893 pump
- Hooker 70101329-RHKR long tube headers for dse sub frame 1st gen fbody.
- FS: Hyperco coilover springs 150 lb rating , used but great condition
- 2018 lt1, 8l90 auto 23000 miles, new edelbrock supercharger, speartech harness, +more
- Speedtech extreme subframe full kit
- TMI Rear Seat Upholstery 64/65 Chevelle
- LSA Pulleys and a Sikky Starter Garage Cleanout Misc.
- 69 camaro VHX gauges
- Ridetech 4 link bars and Anvil Gauge housing for 67-68 Camaro
- Mighty Mouse 2016+ Gen 6 Camaro LT1 Water Pump Mount Catch Can Hardware
- Shop clean out
- Vintage Air Heater Assembly
- LS Serpentine Pulley System
- Centerforce DYAD DS LS7 clutch
- 1998 4L60E Rebuilt Transmission
- 1st Gen Camaro trunk kits.
- Speedtech Suspension Extreme Chassis Ultimate Headers
- 67-69 Camaro/Firebird & 68-74 Nova Sub Frame w/Chassisworks suspension + big brakes
- Ringbrothers Rectangular Mirror Set - Black Chevelle
- ATS A/F/X Spindles & Kore3 Brakes
- Autometer 9117 tach adapter and Autometer 2189 LS Tach Adapter Harness
- 1969 Camaro TMI Sport XR Rear Seat Cover
- New Chris Alston Chassisworks roll cage 1970-81 Camaro -$1,000
- new 1969 Camaro Aluminum Frontend Fenders, Cowl Hood, Header Valance
- New in the box Edelbrock e-force supercharger # 15590 complete setup
- New! G.M. LS9 6.2L 638HP Long Block 12624262 $11,999
- The Shop LLC 1967-69 Camaro/Firebird Kick Panels, Rear Tray, & 10” Sub Enclosure
- ACDelco GM Genuine Parts Harmonic Balancer 12674581 LSA Setup
- Edelbrock stainless LS swap 65073 headers F, A, X body
- Baer Track 4 big brake kit - $800
- FREE Rear Disc Conversion Spacers for LS Rear Discs on Chevy 10/12 Rear Ends
- Freshly Built Gen-V LT1 6.6 Stroker - Katech
- ANVIL Carbon Fiber Header Panel 1969 Camaro
- 1969 CAMARO HEADERS for LS ENGINE-DETROIT SPEED STAINLESS STEEL
- LT4 Holley Mid mount
- E-Stopp Kit
- FiTech Go EFI 600 HP kit
- Autometer Cobalt Blue Gauges for Sale $$$
- LT5 Engine 750HP
- Fresh ls7 ready to go
- 1st gen F-body Ridetech TruTurn kit
- Holley mid mount hemi
- 1968 and 1969 Chevy Chevelle Malibu SS NOS wheel well trim and front end trim
- 64-74 GM A F X Body Shocks, C5/6 Corvette Brakes, Springs, Booster, AFX Spindles
- Holley hp ecu and harness kit 550-607 58x
- T56 Magnum
- Tremec T56 6speed trans
- 1970-81 Camaro/firebird window and door weatherstrip brand new
- C&R Racing Heat exchanger
- 67-69 camaro heidts sbc stainless headers
- 67-69 camaro hooker sbc headers, d-port, stepped, coated
- 1969 Camaro HDX Gauges
- Billet Specialties Rat Tail Forged Wheels
- Complete drop-in '67-72 C10 495hp drivetrain, exhaust, radiator, motor mounts etc
- BBT Pro Edge door handle
- 1969 Camaro Speedtech subframe connectors
- Brodix br-7 heads 273cc sts ported
- New crate Chevy Gen IV 6.0L L96 w/ LS3 upgrades, Holley Drive
- 67/68 Camaro bezel
- New Speedtech AFX/ATS spindles
- OE LS3 coil packs - new
- E-stopp Kit
- Holley 302-03 oil pan
- Asanti wheels
- Lt4/10 speed
- Detroit Speed Selecta speed wiper motor 1969 to 72 Nova, Camaro, Firebird
- 1967-1969 Camaro Detroit Speed HD Leaf Spring Pocket Kit
- 1967-1969 Camaro DSE QuadraLink Rear Suspension Kit Base Shocks WITHOUT Axle Brackets
- Bowler's 8" 30deg blk shift lever
- Baer 6P Disc Brake Kit
- 1967-1968 Camaro Pontiac vintage air system, tilt steering column and wire harness
- Post Project Clean Out
- Post Project Clean Out more parts
- Hotchkis/ Falcon Coil Over Shocks Camaro Chevelle A F Bodies
- TMI Premium 7 piece carpet kit 69 Camaro
- LSA Supercharger LID
- 1967-1969 Camaro Detroit Speed Subframe Connectors
- Misc Parts - Everything Must Go (w/ photos)
- Ricks Tank's for a 1969 Camaro. Walbro 6umps
- 1969 Camaro Dse Dash
- Brand new LS front drive, Boostworx fuel, jms power max , altronics digital switch
- WTB Modified/Damaged Holley Lo/Hi Ram lid with Shortened TB Flange
- Wegner Front Drive Ls3
- FS: Misc Baer Parts (Mustang II spindle)
- 2019 lt1 engine TSP cam kit
- New in box Holley 553-111 12.3 digital dash
- LSA supercharger and Lid
- C6 Z06 LS7 ZR1 LS9 Dry Sump Tank
- 1969 Camaro LSA Build Parts For Sale
- 1969 Camaro LS Air intake (Gray Area Steel)
- Incredible deal on brand new engine and parts
- Stewart Warner gauge set including 5" tach and speedo
- 19" Spal 850 Watt PWM Fan Universal; Huge CFM
- Lokar sport shifter for GM 4L60 and the like, brand new
- DSE Brake booster and master 67-69 camaro/firebird 68/74 nova
- Clayton Machine Works Pedal Assembly - 1967-69 Camaro, 1968-74 Nova, 1964-66 Chevelle
- 67-69 Camaro / Firebird DSE (early design) core support close out panel
- BBC rockers, pushrods and adjustable guideplates
- 70-81 Camaro RB Door Hinges
- New holley injectors
- Wilwood 12.19" Disc Brake Kit (140-7675-D) - GM 64-72 A Body, 67-69 F Body, X Body
- 1970-73 Camaro Z28 Anvil Auto Hood, Fenders, RS Nose, Inner Fenders
- Anvil, cowl panel
- 1967-69 Camaro Carbon Fiber Header Panel
- FS: Ron Davis Radiator Deluxe Dual Electric Fan Controller Kit #200282 - Ships Free
- 67 Chevelle Project Leftovers
- Fesler RS billet taillights 69 Camaro
- Low mileage 5.3, Holley ecu, 4l80e
- 1968 Camaro Subframe with LS2/T56 combo
- DS3 Forgeline, 18x12” w/Tires
- TurnOne Steering Gearbox
- Cleaning Up - 1st Gen Firebird, 2nd Gen Firebird, Mustang, Wilwood parts, etc
- Billet Specialties Tec 5 Wheels & Tires
- Holley terminator x stealth 8-1[emoji646][emoji646]# 555-1[emoji646][emoji646]5
- March 340amp alternator p545 cs130
- Holley hyper spark system
- Sbc f[emoji637] pro charger cog bracket and lower cog
- Wilwood Parking Brake Cables and Brake Pads - New
- Kore3 13" Big Brake Brackets and Machined Impala Hubs for Stock Spindles
- Extreme velocity carb hat
- 4L65E Transmission – 2005 GTO – Built & Ready
- Eddie Motorsport Billet Black door handles New in package
- Wilwood clutch master cylinder - 3/4" bore
- Restomod air setup for 68-72 Nova
- 64-72 GM A Body Ridetech Strongarms
- Coilover Coil Springs
- LS TBSS Intake Manifolds Cathedral & Square Port
- Holley Terminator X with 7" LCD screen
- LSX Tall Deck Block
- LS Valve Covers
- LT4 Longblock New
- Tremec tr6060
- Wilwood Rear Disc Brakes wirh Forged Dynalite-MC4 Rear Parking Brake Kit
- Schott vulcan wheels 18 x 12
- 1969 Camaro redline Firestone Indy 500 tires, center console, carb and intake
- E-Stopp Push-Button Electric Emergency Parking Brake Kit ESK001
