Rb_69camaro
06-14-2025, 03:55 AM
I have a media blasted and painted stock sub frame from a 69 Camaro fitted with Chris Alston's Chassisworks suspension and Wilwood big brakes. There is a Trans crossmember for use with Tremec/Richmond/700R which is from Chassisworks. As well as adjustable black powder coat LS engine mount set from Chassisworks. There is also a Sweet mfg steering box 12:1. All with zero miles. Im thinking of going with an aftermarket sub frame so I can fit bigger wheels up front. I have paperwork and receipts. Some parts arent shown in the pics. Im in the Portland OR metro area. Id prefer to sell the whole lot intact. If I decide to break it up, the suspension kit will need to sell first before the brake kit. Also this kit requires 17" or larger rims.
Price for everything: Paid $7851.10 Asking $5500.
Price for Frame w/ suspension kit, trans crossmember, steering box, engine mounts: Paid $6035.40 Asking 4200.
Suspension includes:
Tubular upper and lower control arms
Varishock double adjustable coilovers w/pivotball Q2
500lb coil over springs powder coat silver
solid sway bar 1" diameter w/ billet alum urethane pivot blocks & end links
bumpsteer set, inner tierods, idler, billet sleeves
Billet aluminum 2" drop spindles w/ billet aluminum steering arms Z28 quick ratio
Wilwood big brake kit:
Black 6 piston forged narrow super lite calipers with pads
13" Spec 37 competition vented rotors
*I also have a Wilwood master cylinder, flexline kit, proportioning valve, and body mount bushings available.2174922174932175002175012175022175032175 04
