traut811
10-29-2025, 10:30 AM
Figured I'd try this here to see what happens. $13,500 for everything below and can show ~$16500 worth of receipts. It would be a turn-key setup from air filter to oil pan, radiator to transmission, headers, exhaust etc etc. 1430 miles on everything below. Made 495 crank hp so should be ~400ish to the wheels. Everything is in the truck so can fire it up and go do donuts if needed. No hiccups and runs really smooth.
I'm putting a TSP LS7 in, so nothing will work anymore.
Will include the following (I'm sure I am missing several things):
383 roller motor
Scat crank and rods
Forged pistons
high volume oil pump
Promaxx 190cc runner/72cc chamber heads
Quick Fuel Slayer 750 carb (pulled Holly Sniper off and went back to a carb and it works great)
RPM airgap intake
Billet specialties billet front runner (with A/C compressor)
Billet specialties valve covers
Edlebrock pro-flow air cleaner
New plugs and Mallory plug boots, wires
MSD pro billet distributor
Full exhaust: Hedman shorty headers, magnaflow mufflers, dumped right before rear end (SWB)
Aluminum radiator and fans
motor mounts (I think dirty dingo, will have to check)
Built 700R4
tubular transmission crossmember
There's a ton of small stuff there. Anodized AN fittings, braided fuel lines, etc etc. I'd be happy to get startup/running videos to whoever if needed.
21881321881421881521885721885421885821885521885621 8853
383 roller motor
Scat crank and rods
Forged pistons
RPM airgap intake
Built 700R4
