View Full Version : 64-74 GM A F X Body Shocks, C5/6 Corvette Brakes, Springs, Booster, AFX Spindles
jwcarguy
10-18-2025, 01:01 PM
I am clearing out extra parts that I have from and for builds that have changed directions
some parts are new, others light use or just mocked up
- new in box Ridetch Streetgrip 2" drop front coil springs 67-69 Camaro / Firebird 68-74 Nova 55-57 Belair
part #11162350 for small block / LS engines
$200
-new pair of Corvette C5 C6 Z51 option front disc brake rotors 13.39" (340mm) drilled and slotted
believe they are PowerStop brand
$180/ pr
-American Touring Specialties ATS "AFX" billet aluminum spindles w/ Corvette C5/6 hub wheel bearings (140 miles)
standard size, uses Corvette C5/6 front brakes (available separately)
$700 SOLD!!
-Ridetech / Fox HQ series front adjustable shocks (mocked up) fit multiple years Camaro Firebird Nova Chevelle Skylark Cutlass Lemans / GTO
part#22149846
$300/ pr SOLD!!
-Hotchkis Tuned /Fox rear adjustable shocks (280 miles) fit multiple years Camaro Firebird Nova Apollo Omega
part # 71030012
$380/ pr SOLD!
- Hotchkis Tuned / Fox 1.5 Street Performance series front adjustable shocks (mocked up) fit multiple years Camaro Firebird Nova Chevelle Skylark Cutlass Lemans / GTO
part# 70030012
$400 / pr SOLD!
- GM Corvette C5 / C6 front disc brake conversion for AFX (300 miles) (needs adapter brackets if using stock GM pin spindle)
black calipers w/ Corvette logo, new pads, 12.80" (325mm) drilled/ slotted rotors , caliper abutments/ mounts, Stainless braided front hoses, GM front hubs modified to fit rotors, has wheel bearings and seals
$400 SOLD!
- Kore 3 brand Corvette C5 / C6 front disc brake conversion for AFX (140 miles) (needs adapter brackets if using stock GM pin spindle) gray calipers w/ Kore 3 logo, no pads, 12.80" (325mm) slotted rotors , caliper abutments/ mounts, Stainless braided front hoses
$350 SOLD!!
-11" Power Brake "Delco Morine" style booster w/ master cylinder, disc brake prop valve and distribution block (stock style)
(used 2000 miles) Disc / Drum setup
believe it is a Right Stuff brand aftermarket unit, not GM
$200
please verify fitment for you applications, not answering fitment questions
pm/call/ text (702)677-4085
in Las Vegas, NV
shipping additional
jwcarguy
01-01-2026, 09:27 AM
Holiday Bump!
