    Page 11 of 32 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 21 ... LastLast
    Results 201 to 220 of 631
    1. #201
      There's still room for a cup holder in front of the shifter! Love this build!
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
    2. #202
      Nov 2002
      Georgetown,TX
      Incredible build. Love the color,too.
    3. #203
      May 2010
      British Columbia
      Quote Originally Posted by OLDFLM View Post
      Thanks man , I actually bought a couple of stainless cup holders but they're just too big . I think I'll look online for a couple more but smaller .
    4. #204
      May 2010
      British Columbia
      Quote Originally Posted by USAZR1 View Post
      Thanks , you're too kind . I love the color as well . I still have to color sand and polish , then as some fool on TV says "it'll shine like a diamond in a goats ass " !
    5. #205
      May 2010
      British Columbia
      This thing is turning out to be Lux!
      lol , I don't know about that . Thanks Andrew
    6. #206
      Quote Originally Posted by langleylad View Post
      It's pretty LUX compared to my original interior and 2/75 AC system!
    7. #207
      May 2010
      British Columbia
      It's been kinda cool out in the shop lately to do any thing constructive but I did manage to order the rear suspension from Summit Racing . I went with the Detroit Speed Quadralink kit . It's built for 66-70 Mustangs but with some slight mods it'll work with my Cougar . I love working with quality parts .
    8. #208
      May 2010
      British Columbia
      Looks like I've got to wait a month and a half for delivery on the rear suspension . In the mean time I can install the headliner , continue on the wiring , figure out how I'm going to run the rear section of the fuel lines , etc ...
    9. #209
      Jan 2011
      Jefferson City, MO
      Glad to hear you're still making progress!
    10. #210
      Cloverdale, BC
      Wow love this build langleylad. I'm in the Langley area too, actually Cloverdale, and would love to see what you've done in person one day. I'm on my 4th Cougar project as I just picked up a nice 68 with plans to slowly do what you are doing after a hiatus of a few years. Think I will eventually go with a Coyote swap as I loved that motor after having a Brown Bros. built modified 2011 Mustang GT convertible for a few years.
    11. #211
      May 2010
      British Columbia
Size:  182.7 KBName:  IMG_0210.jpg
Size:  212.5 KBName:  IMG_0239.jpg
Size:  238.5 KBName:  IMG_0241.jpg
      Finally received my order from DSE and proceeded to cut out the rear floor section . I've got to work slowly as this kit was designed for Mustangs not Cougars . Cougar rear springs are 6 inches longer than Mustangs . The DSE kit is based off of the front rear leaf spring attachment point , so I figure if I move this point in the Cougar rearward 3 inches I should be good to go . So good so far . If I make a mistake the axle won't be centred in the wheelwell . I've also installed a complete Vintage Air A/C set up including their Frontrunner kit . As well as a Be-Cool LS swap rad and Dual Spal fans .Sorry for the sideways photos . I don't have the patience to figure out how to fix it .
    12. #212
      May 2010
      British Columbia
      I would love to run a pwm controller for the fans. These fans can draw up to 100 amps and I haven’t found a controller that can handle 100 amps. Since I’m running a Dominator ECM , I could run dual GM C6 PWMs and stage them . By the time I buy two controllers and two plugs I’ll have close to $500 in them , kinda $$$$ . The Derale piece can’t handle 100 amps ,. Any ideas?.
    13. #213
      Aug 2014
      Use different fans? lol...Most fans I've seen seem to be in the 25-35A range (ea) 100A seems like a LOT.
      Good luck!
      Jay
    14. #214
      Junk yard. 2008ish Ford Fusion controllers. Same as C6. Should run you about $25USD.
      I wouldn't stage them. Just keep it simple and run them together. You'll be able to control the airflow by fan speed. You can score the connectors with the controller. Just buy new terminals from Mouser.
      You can split a single PWM- output into two controllers.
    15. #215
      Nov 2011
      Wylie, Texas
      I think you're confusing inrush current with continuous current. Both fans probably do draw around 100A inrush current but the continuous current is probably closer to 20A each. Any good pwm fan controller should be able to handle the inrush current and continuous current as long as the controller meets the continuous current requirements.
    16. #216
      May 2010
      British Columbia
      Quote Originally Posted by blitzer454 View Post
      Thanks for your reply . I understand that the 100 amps would be inrush . These fans draw approx. 33 amps each continuous .
    17. #217
      May 2010
      British Columbia
      You can split a single pwm- output into two controllers.
      Thanks for the info Andrew .
    18. #218
      Thirty three amps is about what a C6 fan draws. It's 400 watts. Two controllers should work great.
    19. #219
      May 2010
      British Columbia
      Thanks again , glad you're here Andrew
    20. #220
      May 2010
      British Columbia
      Two steps forward , three steps back . One of the problems with working on a tight budget is that you can't buy all your parts at once . Years ago I was able to purchase some of my DSE parts but not everything at once . I purchased the mini tub kit , subframe connectors and two pairs of rear torque boxes . Two pairs to make one pair , the boxes needed to be lengthened to work with the Cougar . So with the modification done and installed along with the connectors and tubs everything looked great . Last forward a couple of years and the purchase of the DSE QuadraLink complete , the last piece of the puzzle . DSE has redesigned the rear torque boxes , much stronger I might add . So today I spent a couple of hours cutting out the old style boxes ( only one side ), damn I did a good job installing the old ones .
