    Results 1 to 10 of 10
      Nov 2025
      'Emma K8' 1969 Camaro
      I have 3 pro touring builds in mind, one for each of my granddaughters. The first is Emma K8, a 1969 Camaro RS/SS. The second is 'Kennedy', a 1973 Trans Am, and the third will be 'Madison', a 1974 Corvette Convertible. If I'm still around, a 4th will be for my first grandson. 'Harvey' will be a mid engined 1969 Mustang Hatchback.
      I give you: Emma K8
      What we have now:
      All new sheet metal body with DSE mini tubs and partially shaved firewall.
      DSE Hydroformed Subframe with Single adjustable coilovers
      DSE Subframe Connectors
      DSE Quadralink Rear
      9" Ford True Trac 3.70
      Wilwood 6/4 piston brakes
      Planned changes coming up in Feb:
      Door handles shaved
      Drip rails shaved
      Flush Glass
      Working right now on
      C7 Z06 Carbon Ceramic Brakes
      2014 Mercedes CLA dash
      Engine Build
      Eventual Specs: Subject to change and will add as we go.
      Engine:
      TSP Resleeved LS 5.3 to 427 big bore
      RHS Pro Elite LS7 Heads with 2.20 Ti intake and 1.615 Stainless exhaust, 400cfm
      BTR custom cam for 3000 stall converter, targeting 650 @6500 on pump gas
      Jesel Pro Aluminum Rockers
      Carbon pTR LS7 intake with 105mm TB
      Transmission: ZF 8HP70 with 3000 stall converter
      Maxx ECU controlling engine and trans
      This is intended to be a high tech build, with features like paddle shifting and ABS.
      More details to come but I gotta get to work for now.
      Name:  Front quarter.jpg
      Name:  Rear quarter.jpg
Size:  67.4 KBName:  Rear Suspension.jpg
Size:  52.3 KBName:  Front Suspension.jpg
Size:  82.5 KBName:  Sub conn.jpg
Size:  70.5 KBName:  Mini tubs.jpg
      Nov 2025
      4 packages arrived today!
      In the crates are the TSP shortblocks. I stayed up until midnight on Black Friday to score these. While I had an immediate need for the -2cc piston unit for Emma Kate, I couldn't pass the opportunity to get the -18cc dished version for the Whipple 427 going in Kennedy. A $9k shortblock for $6500.
      The Painless engine harness arrived as well as the Racepak 12.3" dash. The harness is setup for a GM ECU, but to save 2 grand, I don't mind repinning it for the MaxxECU.
      I've had these heads laying around for 8 years. They were on my C6 Corvette Road race car, sequential shifting at 7500 RPM. Glad I hung onto them.
      Nov 2025
      Do they make a 6" cowl hood?
      Well, the Carbon pTR intake is certainly a no-go.
      With all the conflicting info out there, I just had to see for myself.
      Nov 2025
      A man cannot live on speed alone
      Gotta stop sometime.
      Had to utilize a different spindle than the DSE, since they do not offer a C7 brake option.
      Some work to do to get the steering adapter mounted, but not a huge task.
      Yes, the brake sensor will be wired to the ECU to present an alarm on the dash.
      WARNING: Will require the use of 18" wheels.
      Name:  CC Brakes.png
      Nov 2004
      Paso Robles Ca.
      This is going to be another awesome ride !!!
      1969 Camaro
      1957 Chevy 150 Utility Sedan
      2016 MB AMG-s wagon
      That is a massive rotor! I forget how big those are.
      Impressive build. What spindle did you use to get those C7 calipers to fit?
      Nov 2025
      Nov 2025
      Update 2/22
      Still waiting to get into the sheet metal shop, but busy on several fronts.
      Installing the dash and steering column, from 2014 Mercedes CLA
      Out with the old and in with the new...
Size:  318.8 KBName:  Dash 5.jpg
Size:  320.4 KBName:  Dash 4.jpg
Size:  219.2 KBName:  Dash 6.jpg
      Seats (from 2012 SLK), recovered in the interior scheme.
      Name:  Seats Recovered.jpg
      Chesapeake, VA
      Wow, that is going to be an awesome car.
      Cars are meant to be driven.
      John B
