    Page 2 of 2 FirstFirst 1 2
    Results 21 to 24 of 24
    Thread: suspension
    1. #21
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by struck by Lightning View Post
      So far the best setting has been at 13 clicks (18 total) as all the way (18) will loosen up the rear at entry however most of the track surfaces I've run have been rather rough with the exception of Marina, Ca. The truck performed extremely well at 13 clicks at Marina that I chose not to change a thing.
      My question was mainly trying to see how stiff the rebound could be adjusted on the QA1s. You've already learned firsthand what top tuners know ... you can add rebound in the rear to help tighten corner entry only so far ,,, at at some point ... the rebound is stiff ... but the shock can't hold the car or truck down ... so the tires "get light".
      No first hand knowledge, but Tim reported on the forums that the truck performed very well with good success in AutoX and Club Racing.
      When I looked at Tim's website, it is clear he has tried many different set-ups, documented the changes & results ... and landed on & stuck with a soft spring/big bar setup, that travels the front end more on entry & rolls less. This is a more modern set-up & if fully worked out & dialed in ... will be a little quicker.
    2. #22
      Mar 2013
      Oakdale, Ca.
      This is very true and as a result I reinstalled the trailer hitch and spare tire to add weight. I had removed these items to lighten the truck when drag racing.
      BTW Ron - I just noticed that you are out of Sacramento, are you attending any of the local AutoX events?
      George Dias
      1973 Camaro
      2002 SVT Lightning
      2003 Z06 Corvette
      2015 Truckin Throwdown Champion http://www.trucktrend.com/events/tru...by-ebc-brakes/
    3. #23
      Nov 2012
      Sacramento, CA
      This same effect happens in race cars at a certain point of rear shock rebound stiffness.
      So far, I've only gone to the GG events in Pleasanton.
      Mike Maier has invited me to to the AAS events, but I haven't made it to one yet. Do you run AAS, SCCA or both?
    4. #24
      Mar 2013
      Oakdale, Ca.
      Quote Originally Posted by Ron Sutton View Post
      I have participated in SCCA, AAS and GG events. Please say hello if you ever see the Red Brick at a future event.
      George Dias
      1973 Camaro
      2002 SVT Lightning
      2003 Z06 Corvette
