    Results 1 to 20 of 24
      Holmes Hollow, Ontario Canada
      Best Concrete Paint
      I had to take about a year off to tear apart my old barn piece by piece and build a new garage. Unfortunately I didn't have time to paint the floors before I moved in and started working on the DDs. So the floor now has oil on it here and there and I roll the project cars around on dollies with metal wheels. I would like to paint the floor and would like some recommendations as to what is the absolutely strongest paint I can put on there is that will withstand me dropping tools and rolling cars on metal wheels, the odd drop of brake fluid and plenty of oil. I would probably need to find something that could go over oil. This concrete seems to be really porous and gouges easily. It seems powdery when it gets gouged. So I want to protect it before I screw it up. Any suggestions?
      ____________________________________________
      Scott
      Mar 2004
      Mid-Michigan
      There is nothing you can do. Just as in painting a car, the prep and condition of the substrate is 99% of the job. Painting over a powdering concrete will not protect it. Sounds like the concrete went dry while it was being poured and you can't fix that with a coating. Especially since you are running steel wheels over it. Anything you put over it now will simply delaminate once the concrete "powders" underneath it.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Miami
      I had my gargae floor rhino lined. Help up awesome to oil, tranny fluid etc
      Oct 2012
      Would it be possible to do a skim coat of concrete surfacer? I'm not incredibly knowledgeable with concrete, but seems like an option.
      Oct 2012
      Also, check out Garage Journal's forum, tons of information all directly related to garages. An entire section dedicated to flooring.
      Milwaukee, WI USA
      Quote Originally Posted by jy211 View Post
      Really?!?!
      I've never heard of using it like that.
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
      It gets powdery when gouged - like a pebble blocking a wheel of a dolly. It doesn't bury the pebble. It doesn't gouge with steel wheels alone. I'll have a guy look at that and I understand that prep is key but do you guys know of a product that will not chip off easily assuming prep is done right and holds up to chemicals? How much did it cost to rhino line your floor?
      Scott
      Oct 2006
      McKinney, TX
      Quote Originally Posted by 77thor View Post
      Really?!?!
      Me either....I'd like to see a picture of that if i could...
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Oct 2007
      Camas, WA
      Best Concrete Paint
      Diamond grinder to the entire floor and then use epoxy coat. That is what I did and it holds up well. I have a rotisserie and dollies on my cars and if a rock gets between the wheel and floor it will scratch but that is it. I have had brake fluid sitting on it for 2 months and it slightly did colored it but that is it.
      I went over to garage journal and I think I figured it out. Its a new floor so I don't think I'll need to grind it. My thoughts are epoxy bottom coat with a polyurea clear coat. if I can swing it. I think I need a concrete hardner or densifier first but I have to figure that out.
      Scott
      Jonesboro, Arkansas
      Quote Originally Posted by 68EFIvert View Post
      X2....if you can swing it, this is the ticket.
      Carl Wilson
      Oct 2007
      Camas, WA
      FYI my floor was new as well but the builder put a sealer on the concrete that I did not want. I had to take it off and now I am glad I did. It is holding up great!
      May 2010
      Mooresville, NC
      Quote Originally Posted by Ishmael View Post
      I just did my floor last weekend. My house is 6 years old and had oil spots in the concrete. I am in the homebuilding business, so i spoke to my painter on what product he would recommend I use. He recommended the Sherwin Williams H&C Solid Color Stain. It turned out great.
      But as someone mentioned earlier, the prep work is the key to success. You will first have to degrease the garage floor, I used Simple Green and a scrub brush. Next, you will have prep the concrete. This can be done by sanding or with acid. I used Muratic Acid mixed 1:1 with water. Applied it to the garage slab, let it sit for 2 minutes, then rinsed. This realy gave the concrete a rough finish, something for the stain to bite in to. Lastly, I applied 2 coats of stain, waiting 12 hours between coats. I added an anti skid additive to the last coat so the floor isnt slick when wet. The floor turned out great and I would definitely recommend this product.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Feb 2011
      dallas, tx
      pic?
      May 2010
      Mooresville, NC
      This is a crppy cell phone pic, I'll try to get a few better pics later today.
      Edit: This is the Silver Gray color, one of Sherwin Williams 10 premixed colors. They can color match this stain to any color you would want. The nice thing about going with a factory mixed color is that unopened cans can be returned for a credit.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Newbury Park, CA
      I too did the diamond grinding and epoxy. If I was to do it again I'd still grind but use a stain instead. The epoxy, a top-rated Wolverine product, is not as durable as I would like it to be. Welding will burn it and it scratches pretty easily when parts are dragged across it. The stain will hold up better though it too will stain. Grinding is nice since it smooths the surface and makes sweeping very nice.
      Mar 2013
      NE Illinois (Chicago area)
      Concrete stain, looks great and holds up well. I'm going with the brown tortoise shell in mine.
      Sep 2008
      Jacksonville, Florida
      I used Dupont Corlar as the base and Imron top coat. The epoxy is not UV stable and will chalk if exposed to sunlight. The urethane top coat is UV stable and tough. If sun never hits the floor, epoxy is fine.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      "I own a Mopar, I already know it won't be in stock, won't ship tomorrow, and won't fit without modification."
      Mt.Pleasant Pa.
      Quote Originally Posted by regal454 View Post
      can you add the color flakes to this and use their gloss clear ?
      71 olds cutlass supreme convertible
      07 dodge ram
      96 monte carlo
      11 dodge challenger
      http://www.fquick.com/724TIM
      http://s297.photobucket.com/albums/mm206/724tim/
      Mt.Pleasant Pa.
      how big was your area and how is the coverage , I looked at their concrete paint I think they said 1 gallon will cover 250 square feet .
      07 dodge ram
      96 monte carlo
      11 dodge challenger
