    Results 1 to 9 of 9
      Aug 2011
      Connecticut
      First gen F-Body tire size? (What fits)
      Please post up your tire sizes on your first gen Camaro and Firebirds. I want to run a 315/35-17 on the rears and I don't know if they will fit. Any suggestions?
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
      Oct 2011
      El Dorado AR
      I had 315/35/17 under my 67 Camero. I just mini tubed and went to a 335/30/18.
      Jul 2007
      Olathe, KS
      Elrod, 315's without a minitub? What magic wand are you using?
      With wheel tubs I extended 2.75" I have a total of 15" (381mm) from inner fender well to quarter lip.
      Stock that same measurement would be 12.25 (311mm). I can't possibly see how you wouldn't have severe rubbing issues.
      Aug 2011
      Connecticut
      Just poking my head under the car yesterday... There is no way of running the tires I want with out mini tubs
      New updated thread
      Aug 2011
      Connecticut
      http://www.detroitspeed.com/1967-196...i-tub-kit.html
      Probably going to buy one of these kits
      New updated thread
      Jul 2007
      Olathe, KS
      With a minitub you should have no problems with the correct wheel fitment.
      Aug 2011
      Connecticut
      Quote Originally Posted by Rhino View Post
      I would like to run 17x10's in the rear just need to figure out back spacing
      New updated thread
      Jul 2007
      Olathe, KS
      You're going to need a wider wheel. I'm pretty certain most 315's recommended minimum is 11". It's much more preferred to be on the high end of the recommended wheel width to flatten out the tire and provide a more predictable sidewall.
      With a stock width rear axle you'll want roughly 4.25 - 4.5" of front space. Everything else needs to be backspace.
      Aug 2011
      Connecticut
      I actually meant 11" wheel :(
      Posted that this morning before my coffee on the John
      New updated thread
