    Results 1 to 9 of 9
      Dec 2007
      Bay Area, CA
      T-56 shifter compatability question
      I have a T-56 out of a 2004 GTO (first photo). Notice how the shifter is set back; there is a linkage in the shift plate that moves the shifter to the rear. I want to eliminate this linkage like a normal T-56 so the shifter is further forward.
      When the GTO shifter plate is removed (second photo), the tranny appears to be the same as a Camaro T-56. It would appear that I can just bolt on a Camaro T-56 shifter like a Hurst or B&M (third photo)and my problem is solved.
      Can anyone comfirm that this will work?
      Steve
      Central NJ
      It sure looks that way to me.
      Mar 2012
      gto shifter
      I think you need to change the cup at the end of the shift rail to a camaro one
      Just knock out roll pin and swap
      the gearbox.com has them
      Dec 2007
      Bay Area, CA
      Quote Originally Posted by nathanr15 View Post
      Thanks. I tried gearbox.com and it is a audio-video production company. Any chance of getting a link to the right company? Thanks.
      Mar 2012
      Sorry Steve it is thegearbox.org
      http://www.thegearbox.org/catalog/it...17/7328789.htm
      this the part I was talking about. any camaro t56 shifter should fit after mod
      Dec 2007
      Bay Area, CA
      Thank you.
      Is the reason I need that part because the camaro/firebird shifter is offset to one side and the GTO is centered?
      Mar 2012
      No I don't know why they Call it offset lever . But the difference is length. if you look at the pics yours is longer from the rollpin to the socket than the camaro one.
      Apr 2010
      Jersey Shore
      Ive got the same trans... Nathan is correct. Just swap out the shifter cup for an F-body one and you can bolt up any F-body shifter.
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Dec 2007
      Bay Area, CA
      Quote Originally Posted by vette427-sbc View Post
      Thanks guys.
