      Mar 2013
      Galt Ca
      Impala AC Problem
      I'm have a problem with my ac only 2 out of 4 vents are blowing cold air. The other 2 vents barley have any air blowing from them. I don't know much about Air Conditioning and don't want just anyone to take apart my dash to get to the vents and possibly crack it or break a mounting bracket. My question is a simple what could be the problem?
      Mountain Springs, Texas
      Did you call VA? They are quite helpful when I give them a call.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      I'd check to make sure the air tubes (hose) are still tightly connected to the plenum and the air ports.
      ​John Parsons
      Southern Indiana
      You may also have to restrict down the two that are blowing too much, remember air is like water, it follows path of least resistance. Had to build restrictors for several cars that ran long lines and short lines. man systems would benefit from being adjusted with restrictors any way. Also make sure ducting, if flexible , isnt kinked. another thing I found was that several VA systems I worked on had got critters building nests, in supposedly clean, sealed shops. rodents left but homes were still there. and these were high dollar cars too.
      Good Luck
      Lee Abel
      AFTERMARKET PERFORMANCE
