    Page 2 of 2 FirstFirst 1 2
    Results 21 to 21 of 21
    1. #21
      Apr 2010
      Pittsburgh, PA
      Every time I research the hid topic throughout the years the more I learn whats really ideal, and whats right and wrong..
      I first thought it'd be ok if installed in an ECE housing..since on Daniel Sterns site he mentioned HIDS first came out in reflector housings.
      found out a real HIDs are equipped with a projector..not just a Xeon bulb and ballasts..
      I've heard that theirs Xeon bulbs made for both reflector and projector housings..D"*"S for projector...D"*"R for reflector I personally havent found anything, Jury is still out on this one :-)
      You can retro fit a projector and use a quality xeonbulb and ballast from the site I linked, but the flutes on the h1/h4 housing will shorten the lighting distance and shift some light to the side with at least 1 or 2 hot spots above the beam cutoff..
      this can be possibly removed but at least reduced if you sand down the flutes on the glass housing or plastic housing...which is why I suggested the cheap ebay projector housings for the clear non fluted glass housing lens..plus easier to elongate a projector hole for a real projector versus starting a hole for said projector while also having to deal with sanding down lens and possible ruining it in process.
      and anything above 6k is pointless as our eyes arnt made to see it and gives us an illusion of better vision whereas lighting distance is actually reduced..4300/5000k is the HID spectrum you should get
      i'm still no lighting expert but I know what not to do
      and xeonbulbs with ballast in reflector housing that lack projectors are one of them
      EDIT
      Also wanted to note that some Ballasts use ac while others use DC current....some are almost if not completely water-proof..atleast a select few brands
      so for Ballast you want to look for a digital Ballast that uses AC not DC, nor should you use an Anolog ballast(are they still around?) and if water/dustproof the better :-) EDIT
      72 buick skylark
