Results 1 to 20 of 29
Thread: Engine compartment venting
- Mar 2008
- 952
i didn't use any mathematical formulas- hell, i don't know if they even do any good- but here's the fender vents i put in the hood of my 86 Camaro.. you can see quite a bit of heat radiating out of them at stop signs when the electric fan kicks on...
and, yes, they are heat register covers that i got from Home Depot.. and also notice how far back they are- the front edge of the vent is about an inch back from the radiator support.. they'd probably be more effective if they were up closer to the leading edge of the hood, but this was as close as i could get them without making up some fancy ductwork or something under the hood..
here is a closer look at some of the other supporting aero mods i've done to the car... it's no longer a "bottom breather"- all the air that goes thru the radiator and into the air intake goes thru the grille and is directed to the proper places with an airbox made out of coroplast... the car kept it's cool and the carb was kept fed with cool air thru the open part of the grille way at the bottom that doesn't have the duct tape-oops, i mean "racer's tape"- on it.. i'm sure the hood vents allow me to get away with a smaller opening, which also helps the aero of the car in addition to the venting of heat. taping off most of the grille gained me 2mpg...
the beauty of owning a POS is that you can do fugly stuff like this and see if it has any benefits...
