    Page 25 of 29 FirstFirst ... 15 20 21 22 23 24 25 26 27 28 29 LastLast
    Results 481 to 500 of 578
    Thread: 69 GTO Build
    1. #481
      Charlestown NH
      Like I mentioned when I get my truck going Ill come down and spare some motivation. How far are you from Chris cerce customs??
      https://www.pro-touring.com/showthre...-Touring-Truck
      DMP Fabrication LLC
      Follow me on Instagram for welding and truck progress! - Americangraffiti
    2. #482
      Jun 2012
      N. Shore, Ma
      To Do List...
      It would be an honor to have you down sometime and help get me inspired. I am on the North Shore so pretty far from Taunton, looks like they do nice work there.
      Feels like there is so much to do and the list never ends. I am sure when I hear it fire up for the first time it will make me want to finish to get it out on the road again.
      Every so often I need to remind myself how far the GTO has come from when I bought it 33 years ago.
      Name:  6.1985 GTO and Custom S.jpg
      Name:  6.1985 GTO Nose off.jpg
      Name:  7.1985 GTO frame off.jpg
      Eric
    3. #483
      Jun 2012
      N. Shore, Ma
      Custom Dash
      Ok this took a while but I made some progress on dash, so many little custom brackets.
      Speedhut gauges installed, new Flaming River tilt column, Ron Francis key-less ignition (RFW-IS10)
      Still lots to do but happy to be working on it again!
Size:  170.0 KBName:  IMG_9036.jpg
Size:  176.6 KBName:  IMG_9162.jpg
      Eric
    4. #484
      Jun 2012
      N. Shore, Ma
      3in Exhaust
      Quick update,
      I finished welding the the exhaust up to the mufflers, going to do tailpipes under rear end later.
      Went with the black Speedway bushings for the mount brackets close to pipe since they have a higher temp rating.
      PN 91000118
Size:  136.4 KBName:  IMG_0676.jpg
      Rear mount bracket before fully welded.
Size:  101.4 KBName:  IMG_0823.jpg
      DEI Titanium wrap 2" x 100' roll
      Used the adhesive spray on the exhaust to help wrap it tight, I am sure it will burn off. Will be adding more stainless zip ties.
Size:  168.0 KBName:  IMG_0848.jpg
Size:  116.1 KBName:  IMG_0863.jpg
      Ball flange from Summit PN JBC-997301
      Eric
    5. #485
      Jun 2012
      N. Shore, Ma
      Sideways pics
      Still checking things off the list, heat shields, fuel lines, AC, gauges and lots of wiring.
Size:  116.5 KBName:  IMG_0902.jpg
Size:  149.9 KBName:  IMG_0904.jpg
Size:  139.7 KBName:  IMG_1577.jpg
Size:  157.0 KBName:  IMG_1573.jpg
      Eric
    6. #486
      What product are you using for the heat shield under the car?
    7. #487
      Jun 2012
      N. Shore, Ma
      Hey Andrew,
      For the trans tunnel I went with a sheet of Speedway Motors, Aluminized Heat Barrier, 40 x 36 Inch PN 70414001 and I used silicone to adhere.
      For the bottom of the floors I used DEI adhesive backed Floor and Tunnel Shield, with the DEI tape perimeter.
      Eric
    8. #488
      May 2010
      British Columbia
      Quote Originally Posted by ekmxryda View Post
      Hey Andrew,
      I used the same DEI product between my mufflers and floorpan , simple install .
    9. #489
      Thanks guys!
    10. #490
      Jun 2012
      N. Shore, Ma
      Radiator
      Sorry for the lack of updates, still getting things off the list.
Size:  155.8 KBName:  IMG_4040.jpg
Size:  146.7 KBName:  IMG_4104.jpg
Size:  140.7 KBName:  IMG_4201.jpg
      Eric
    11. #491
      Jun 2012
      N. Shore, Ma
      Fuel
      I have been picking away at all the details for a while now, but it will be a big boost for my motivation to push hard and get things done once I hear it run.
      Excited that my buddy who owns a well established Porsche speed shop will soon be sorting out the wiring and helping me finally get it fired up.
      http://autobahnperformance.com/
      Hoping to drop it off in a week or so.
      Looking for tips on what type of gas to dump into the fuel cell?
      Was thinking the Sunoco 260 GTX 98 Octane Race Fuel?
      I really dont want to have an ethanol fuel sitting in the lines for months while car is still being worked on.
      Crossing my fingers that all goes well.
      Will be filling, bleeding, priming fluids this week.
      Lucas Oil promotion!
      Temporary tubes connect radiator support for transport / possible parking lot test driving.
      Eric
    12. #492
      Jun 2012
      N. Shore, Ma
      Wiring
      Super excited!
      Was able to drop GTO off at the shop this week and the guys started tearing into it right away.
      Eric
    13. #493
      Jun 2012
      N. Shore, Ma
      Halogen Headlight Conversion
      Getting some of the little things done while the wiring is getting finished.
      After searching most of the posts here on headlights I went with a set of the Autopal Halogens.
      http://rimiusa.com/index.php?main_page=index&cPath=12
      Blacked out headlight trim and grills since the chrome was pretty rough.
Size:  201.3 KB Name:  IMG_4656.jpg
Size:  102.0 KB Name:  IMG_4658.jpg
Size:  244.6 KB Name:  IMG_4674.jpg
      Eric
    14. #494
      Jun 2012
      N. Shore, Ma
      First start
      Amazing day today, got to fire up the GTO and test out the clutch and brakes in the parking lot!
      So glad that things went smoothly, only had a couple fittings that leaked, power steering fluid and one at the oil cooler, just had too finish tightening them.
      We cranked it over (with fuel pump relay out) on and off for maybe one minute total until we saw oil pressure. Then once the fuel pump cycled a couple times it fired up, I had to pedal it and keep giving it some gas to keep it running. We noticed after that the throttle body was totally shut so after adjusting the stop it fired up much quicker and had a better idle. Once we adjusted the fuel pressure regulator to around 65 it was happier too.
      Still a long way to go but this is a big push in the right direction.
      I need to figure out how to post a video here, will try tomorrow.
      Sometimes I post quick updates when I cant find the time to update the thread here so if you guys want to follow along on my Instagram it is ekmxryda
      Name:  GTO first run.jpg
      Eric
    15. #495
      Big day! Congratulations.
    16. #496
      Jun 2012
      N. Shore, Ma
      First day
      Thanks Andrew!
      I will post more pics and once I figure out what format the video upload wants I will attach a video, sorry for my lack of skills.
      If you want to hear it running check out my Instagram.
      https://www.instagram.com/ekmxryda/
      Eric
    17. #497
      Jun 2020
      TX/MX
      Subscribed!
    18. #498
      NICE! Congrats!
    19. #499
      Jun 2012
      N. Shore, Ma
      Progress
      Still making slow progress, this year has been tough.
      I was finally able to widen the inner fenderwells last week.
      Raptor lined the insides.
      Hope to bolt the fenders on tomorrow.
      Attachment 181745
      [ ATTACH=CONFIG]181748[/ATTACH]
      Eric
    20. #500
      Let's get this ride on the road!
    Tags for this Thread
