    Page 2 of 2 FirstFirst 1 2
    Results 21 to 26 of 26
    1. #21
      Nov 2010
      Ontario
      Yeah just googled Jacksonville NC, not that far from him.
      I thought the gage and sender had to be compatible, can't mix and match is what I thought.
      Going into the 56 Sport Coupe in the avatar. I built a 355 with alum heads and hyd roller. Approx 475/hp with 9" and 3.89 gears. Can't wait til spring.
      You got yours in the Camaro?
    2. #22
      Nov 2009
      Jacksonville NC
      Yes, Have it in a 68 Camaro RS. Have run it a few times at the track as well (10.6 in the Qtr without any tuning of the suspension). Another thought just in case you run into it. With the Easy TV system they have it calibrated using their plunger in the tranny. When Lonnie built mine he said the plunger he uses will be good, but I had trouble when I went WOT the plunger would bottom out and I actually was not at WOT. So use if you have this issue and you don't have enough adjustment to fix the problem then install the one from the kit. You may not have this issue, but in case you do. I just installed the New Fast 2.0 in mine, still trying to get it to be perfect............
    3. #23
      Nov 2009
      Jacksonville NC
      Also on the gauge/sender best thing to do is call a company (like AEM) and ask them if your use one of their 0-300 sensors, what gauge can or will work with it. I think thats what I originally did, but ended up with my current set-up.
    4. #24
      Nov 2010
      Ontario
      NICE... 10.6
      Lonnie set me up the same way with the plunger spring from him. As per how Lonnie told me to set it up was with the pan off and driver activate the gas pedal and watch for plunger to reach full TV just as I reach WOT at the carb.
      Sounds like we both got the same speech lol.
      Heard all great things about that man.
      Here in Canada everyone knows the 700r and the mention of the 2004-r, they just look at me as if I'm crazy. Gotta make a trip to Lonnie, lol.
      What gage set up are you using? Part numbers would help, remember I'm Canadian and don't have all these suppliers readily available, there is this thing called a border and anything that crosses it, costs multiply. Ask me how I know lol.
    5. #25
      Nov 2009
      Jacksonville NC
      Yes exactly what he said is correct. Except I could not adjust mine out enough to reach WOT because the plunger was bottomed out. I gave Lonnie the one from BTO and explained to him they said I needed to use theirs but he said his would work, when it didn't I called him and he just made me one that was the same as the one from BTO, and sent it to me. So far love how it performs, and with a 2yr warranty not bad, plus he is more than ready to help out.
    6. #26
      Nov 2010
      Ontario
      Just seen the FAST 2.0 video........WOW nice clean car!!
      If you come up with the sender and gage number let me know.
      battery going on my iPad, almost ready to shut down.
      Good chatting and Merry Christmas.
