    Results 1 to 20 of 26
      Jul 2011
      200r4 experiences?
      I am in the process of changing to a 200r4 transmission in my street rod. The engine made 640hp and 595 ft./lbs torque on the dyno. I currently have a TH350 transmission. Can someone share their experince with this type changeover? I want a quality, durable transmission and dont want to "cut corners", as everything else on the car has been detailed nice.
      Camarillo, California
      I ran a 200R4 in my Nova SS for years. With both a big block and a small block. Although I never ran anything near the horsepower you are going at. I never had a problem but I had a guy who was real good build it. Had the power on full time and setup the ground to my cigarette lighter. So I push it in and the converter locked up. I have never heard of anyone running that much power in front of that transmission.
      Jake
      After much research, consideration, and experimentation, I have decided that adulthood is not for me. Thank you for the opportunity.
      Oct 2011
      Peru, IN
      Search any turbo Buick forum for information about the 200r4 and what should be done to survive high HP applications. I can tell you from experience that a stock or mildly built one won't last long in your application. If you want to talk to somebody about one or you're thinking about a purchase/modification of the one you have I highly suggest you contact Lonnie Diers of Extreme Automatics. (513) 898-0553. (Hope that's still his number....) Stand up guy who finally got my $3300 setup I bought from another 'expert' to work.
      Building a GN to carve corners and travel long distances. *inprogress* Ridetech Coil-Over Tru-Turn Suspension, custom paint by child's tricycle handle, Baer Brakes, 6152turbo, 2800stall, Lonnie Diers Transmission, factory installed T-Top water leak, Casper custom harness, hanging on for dear life vacuum line setup, homebrew ported heads, Translator2, AEM TruBoost control, Good looks by GM, oil and gas by fossils, slightly understanding wife mod, Praise Jesus it runs installation, and Baer Brakes for the 'whoa.' R.I.P. Powermaster 1987-2004.
      Erie, PA
      Ran an Art Carr-built 200R4 behind a ZZ4 crate engine in my 86 Monte for years and now have that tranny installed in my Big Block Monte as well. No problems when its built right...
      Andreas
      www.fgmcc.com
      Aug 2012
      Warsaw mo
      you can get them to handle big power but it can cost a bit.art carr is the men to talk to.
      72' monte . Factory number matching 454.
      Jul 2011
      Thanks everyone, and after researching; I believe I am going to order a Stage 3 unit from Lonnie at Extreme Automatics and a new torque converter. I have been impressed with the feedback regarding his 200r4 experience.
      Jan 2013
      Did u get your trans yet wanted to know how did u like it ?
      Nov 2009
      Jacksonville NC
      I also have the 2004R Stage 3 built by Extreme Automatics with his Trans Brake, and a 3500 convertor came with a 2yr warranty. I have had it installed for several months now, and love it.
      Nov 2010
      Ontario
      I did some searching and came across Loni Diers Extreme Automatics and picked up his Stage II.
      Doing the swap this winter and will check in the spring. Only four more months
      Apparently his Stage III can handle cars into the 9's.
      Cheers!
      Jan 2013
      200r4 experiences?
      What TV cable are u going with
      Nov 2010
      Ontario
      I had planned on the TV Made EZ but now comparing to Bowler.
      Will order soon.
      Nov 2010
      Ontario
      Will order soon.
      Wonder which one one obengston used? Hint, hint.
      Nov 2009
      Jacksonville NC
      Quote Originally Posted by sportcoupe View Post
      Will order soon.
      I used the Bow Tie overdrive setup TV Made EZ (http://www.bowtieoverdrives.com/cata...php?ITEMID=218) , but the only thing with this is the bracket is flexing where the cable connects, which is not good because it can change your overall set-up. I'm okay with it only because I installed a pressure sensor on the side port of the transmission (the same port they say to put a mechanical pressure gauge when setting up the tranny). This way I'm always monitoring the pressure through all gears at all times. The biggest killer in these transmission I feel is not having the pressure correct. If the bracket bends to much or something happens I will see it on the pressure gauge, which I have connected to my Dakota Dash (but you can always add a external gauge inside the vehicle as well.
      Nov 2010
      Ontario
      Thanks for the quick reply, got my hint. Lol
      I'm back with TV Made EZ and best to add an on board pressure gage.
      TCI mech gage may be on the list, Autometer only make a temp gage no psi gage.
      What do you think?
      Nov 2009
      Jacksonville NC
      What do you think?
      Link me to what your talking about. I personally would only use one the uses a sensor, would not run any mechanical inside the car with pressure that high (just me)
      Nov 2010
      Ontario
      Can't seem to link it with my iPad, #801100 TCI from Jegs.
      Never gave it a thought of running 300psi into the car, guess I would know if it leaks pretty quick.
      I would run it with the -4 braided line kit not the plastic or copper 1/8" line.
      Would that be better?
      Nov 2009
      Jacksonville NC
      I guess it would be a little better. IMHO why would you not just get a 0-300 pressure sensor and run it to a gauge with just wiring just seems safer and easier, and if you use a digital gauge you get a exact pressure with just a quick glance while driving. Plus it is easier to route wire. Your way I guess will work, just not the way I would go.
      Nov 2009
      Jacksonville NC
      Have you already ordered your tranny?, and are you installing it?
      Nov 2010
      Ontario
      Most the dirty work is done, got the trans from Lonnie when I was down in Virgina Beach vacation, day trip to Bethel NC. Shipping to Canada would kill me and a purchase like that, I want to be there.
      Worth the trip.
      I did the install myself, now just the little time consuming things before it comes off the stands.
      What gage and wiring options do I have to go electrical like you say? Interior is all stock and was thinking of putting this gage in the glove box. Only gage got is a tach on the column.
      I actually have the TV Made EZ because Lonnie recommended that. The thread about the Bowler kit caught my attention because everywhere I've read, you NEED to check pressure regardless what kit you use.
      Nov 2009
      Jacksonville NC
      I live about a hour drive from Bethel, was glad he moved his business there, because like you I like to speak to the person in person If I can. I have one gauge mounted in the glove box, which is my tranny temp gauge. So if thats where your wanting to put your pressure gauge I would go Digital, because you could easily open the glove box while driving and see what the pressure is easily. Any pressure sensor 0-300, and wire it to any gauge that will read 0-300 pressure. No different than the oil pressure gauge except a higher reading. What type of car is it going in? I will see if I can find the gauge and sensor I was going to use before I ended up with the Dakota Digital Dash and wired mine to that.
