      Colorado Springs
      Understanding the T56
      I'm thinking about jumping into the T56 playground and have seen a lot of differing info that leaves me a bit shell shocked. Since the sticky above has lost some of its links and I'm somewhat late model illerate, I'm not quite sure what some of the differences are. I've seen T56s called out as Viper trans, LT trans, LS trans, Mustangs trans, etc. I'd imagine shifter locations vary and maybe bolt patterns, but I'd suspect the transmisssion its self are all the same, or are they? I notice Quick time sells adapters for my engines, but they also specify different trans such as LT, LS, Magnum, etc.
      Does anyone have a primer on the differences, break down of styles, donor cars, etc and/or can you point me to a publication that may have that info. I would sure appreciate it.
      TonyC@HP2
      Aug 2009
      Really good thread on the T56:
      http://www.camaros.net/forums/showthread.php?t=98387
      Hope that's useful!
      In case that link ever dies:
      There are so many questions from folks about how to do this swap, I thought I'd
      post up a little "primer" I did. The post will be in two parts. All
      recommendations are solely my own. Any corrections or comments are welcome
      The Principal Choices of Swappable
      T56’s
      There are
      three T56’s that are generally used in first generation Camaros.
      T56’s that were in
      an LS1 equipped GM car (Camaro
      or Firebird – not a Corvette) these are
      referred to as “LS1 T56’s”; T56’s that were in LT1 equipped GM cars (Camaros and
      Firebirds) these are referred to as “LT1 T56’s”; and so-called Aftermarket T56’s
      that were intended by Tremec and GM as service replacements for T5’s that broke
      behind (I think) TPI SBC’s, these are referred to as “Aftermarket T56’s.” The
      Aftermarket T56’s came with an adapter plate very much like the McLeod 8207 kit
      referred to below, except that the
      adapter plate was drilled to correct for the 17 degree tilt built in to the T5
      bellhousings. If you get a new Aftermarket T56,
      you’ll have to have the plate redrilled, or get yourself a T5 bellhousing.
      The LS1 T56's generally and many LT1 T56’s have a 0.5:1
      overdrive sixth gear and a 2.66:1 first gear with an overall gear spread of
      2.66-1st,
      1.78-2nd, 1.30-3rd, 1.00-4th, 0.74-5th and 0.50-6th,.
      Some of the very early LT1 T56's, the Aftermarket T56 and a
      few other more exotic T56's have a 0.62:1 sixth gear and a 2.97:1 first gear
      2.97-1st, 2.07-2nd, 1.43- 3rd, 1.00-4th, 0.80-5th and
      0.62-6th
      . The splits between the gears
      for the LS1 T56 are: 0.67 1-2, 0.73 2-3, 0.77
      3-4, 0.74 4-6, 0.68 5-6. The splits between the gears for a 2.97 first gear T56
      are: 0.70 1-2, 0.69 2-3, 0.70 3-4, 0.80 4-6, 0.78 5-6.
      Because of the steep overdrive 6th gear
      in an LS1 T56, a car with a radical cam will
      need a rear gear at the higher end of the range. By way of example, given a
      26.6” tall rear tire and an LS1 T56, a car with 4.11 gears will be
      turning about 1560 RPM at 60mph, and will go about 77 mph at 2,000 RPM. A
      similar car with 3.55 gears will be turning about 1350 RPM at 60mph, and will go
      about 89mph at 2,000 RPM. Yet another similar car with 3.08 gears will be
      turning about 1170 RPM at 60mph, and will go about 103 mph at 2,000 RPM (if the
      engine makes enough torque).
      The equivalent numbers for a similar car equipped with a T56
      with a 0.62:1 6th gear are: 4.11 gears will be turning about 1930 RPM at 60mph,
      and will go about 62 mph at 2,000 RPM; 3.55 gears will be turning about 1670 RPM
      at 60mph, and will go about 72mph at 2,000 RPM; and 3.08 gears will be turning
      about 1450 RPM at 60mph, and will go about 82 mph at 2,000
      RPM.
      Finally, the 2.97:1 first gear T56’s are generally rated by
      Tremec for 400Ft-Lbs of torque. The 2.66:1 first gear T56’s are generally rated
      by Tremec for 450Ft-Lbs of torque or more. Both are, based on abuse stories,
      pretty conservative ratings.
      You can tell the difference between an LS1 T56 and an LT1 T56 three ways:
      (1) The LT1 T56 has the slave cylinder mounted
      on the bellhousing
      and the cylinder pushes the outside end of the clutch fork toward the front of
      the car. The LS1 T56 has a hydraulic throwout bearing that bolts to the front of
      the transmission and is concentric with the input shaft.
      (2) The LT1 T56 has a clutch fork
      pivot ball on the front of the transmission. The LS1 T56 has no provision for a
      clutch fork pivot ball.
      (3) The LT1 T56 input shaft is about 5" long from the face of
      the transmission (where it's bolted to the bellhousing) to the end of the input shaft. The LS1
      T56 input shaft (measured the same way) is about 6.5"
      long.
      The best way to determine the gear set in an LT1 T56 is to put
      it in first gear and count number of input shaft revolutions required for one
      full revolution of the output shaft.
      (The
      Aftermarket T56 has an input shaft that is 7” from the face of the transmission to the end of the input
      shaft and doesn’t come with a bellhousing; the Viper
      T56 has an input
      shaft that is also about 7” from the face of the transmission to the end of the input
      shaft and has no provision for a clutch fork pivot ball.)
      Swapping
      an
      LS1 T56
      If you’re starting from scratch and already have a 3 or 4
      speed manual transmission in the car, the easiest and cleanest way to swap a T56
      into a first generation Camaro behind a traditional BBC/SBC is as follows: You
      will need an
      LS1 T56, the McLeod adapter kit (1/2” thick adapter
      plate that goes between the transmission and the bellhousing, extended pilot
      bushing, and “collar” on which the throwout bearing rides – McLeod Part No.
      8-207 available, for example, at http://store.summitracing.com/partdetail.asp?part=MCL%2D8%2D207&N=700+400374+429
      4812239+4294856873+115&autoview=sku
      ), a transmission cross
      member (I like the ATS adjustable crossmember available at http://www.t56kit.com/main.html), a
      shortened balanced driveshaft (which
      you can have made up locally), and an electronic speedometer or an electronic to
      mechanical converter such as
      Cable X (available at http://www.gaugeguys.com/cablex.htm, among others).
      Using these parts you reuse your current
      bellhousing, clutch setup (swapping in a 26 spline disk if required), throwout
      fork, throwout bearing and mechanical clutch linkage. I also prefer an all heim
      joint linkage such as the one available from http://www.speeddirect.com/index.aspx?nodeID=34.
      If you are converting from an automatic, you
      will also need a bellhousing or scattershield for a SBC/BBC, a flywheel, clutch and 26 spline
      clutch disk for a traditional SBC/BBC, clutch pedal, clutch linkage (upper rod,
      Z bar, and lower linkage (or just buy the Z bar and purchase the heim joint kit
      referred to above), throwout fork, throwout fork pivot ball and throwout
      bearing. All of these factory style linkage parts should be available from your
      preferred restoration part vendor.
      I prefer
      a mechanical clutch linkage, particularly for an LS1 T56, because
      troubleshooting and correcting clutch engagement/disengagement problems with the
      factory hydraulic linkage generally requires that you uninstall the roughly 130
      pound LS1 T56 to get to the concentric throwout bearing, make whatever
      correction you think is needed, reinstall the transmission, test again and then
      go through the uninstall/correction/reinstall sequence until the problem is
      solved. Call me lazy, but that doesn’t sound like fun.
      If you want to use the factory hydraulic linkage with either
      the LS1 or LT1 T56, I suggest you simply use the
      ATS kit available at http://www.t56kit.com/main.html. The ATS kits use
      the factory hydraulic linkages and the factory bellhousings.
      Weir Hot
      Rod Products also makes conversion kits for
      LS1 or LT1 T56’s (http://www.weirhotrodproducts.com/index.html) which
      use Weir’s cast aluminum bellhousing and hydraulic linkages (which use a
      concentric hydraulic throwout bearing for both transmissions), but which, in my
      opinion, aren’t as polished as the ATS kits. (Compare the Weir cross member to
      the ATS piece.)
      Finally McLeod (whose adapter
      kit is mentioned above) also makes a “modular” bellhousing which is a
      hydroformed steel bellhousing that uses spacer rings of various thicknesses and
      transmission mounting plates to adapt a variety of transmissions to a variety of
      engines. (If you’re doing anything other than a T56 behind a GM engine, talk to
      McLeod.) In addition, McLeod makes front “intermediate” plates for T56’s that
      incorporate a clutch fork pivot for adapting an LS1/Viper T56 to a mechanical
      clutch setup without the use of the adapter plate kit. A modular bellhousing and
      McLeod front “intermediate” plate locates the transmission roughly 0.75” closer
      to the engine, increases the effective amount of space in the transmission
      tunnel (because the transmission is farther forward) and makes the installation
      cleaner, simpler but more expensive.
      Swapping an LT1 T56
      If you
      already have an LT1 T56, your swap is a bit more involved (and likely costly).
      As described above, the LT1 T56 has a fairly short input shaft which, because of
      limited space between the transmission and the engine block, requires the use of a special “pull” style
      clutch and a special flywheel designed to accept the
      “pull” style clutch. (Here’s a picture of the clutch just by way of example http://www.clutchcityonline.com/images/04-134.JPG)
      You can’t use any "standard" Chevy flywheel and, unless you have a
      one piece rear main seal crankshaft, you also can't use the factory LT1
      flywheel. In addition, the LT1 T6 uses a hydraulic linkage with a slave cylinder
      external to the bellhousing, which is also “one-off” for the LT1. So if you’re
      going to install an LT1 T56, make sure you get the bellhousing, the clutch (if
      it’s in good shape) and the hydraulic linkage.
      Once you
      have the basic parts you have four choices: (1) You can use the ATS kit, (2) you
      can use the Weir kit, (3) you can contact McLeod’s tech line to see if either
      the adapter kit mentioned above with a more extended pilot bushing or one of
      their modular bellhousings will work, or (4) if you have a 2.66:1 first gear LT1 T56, you can swap out the input
      shaft for an LS1 T56 input shaft and go to the section above. (You can also swap
      the Viper T56 input shaft for an LS1 T56
      input shaft to simplify installation of a Viper T56 behind a SBC/BBC LSx engine.)
      If you swap input shafts, be aware that the input shaft must be correctly
      shimmed on a T56, so it would be best to have an experienced transmission
      technician do the job.
      Interior Details
      With any
      of the mounting methods used you’ll need to cut a new hole in the transmission
      tunnel for the shifter handle and you’ll need a shift boot sealing the floor of
      the car to the outside air. The LS1 T56 and LT1 T56’s move the shifter back the
      most, the Viper T56 less and the Aftermarket T56 the least. However, all of them
      require a new hole for the shift lever at least 4” or so back from the factory
      location. (The shifter location itself, however, is fine with any of them.) If
      you have a console, it will have to be moved back, or you’ll have to try
      something like the McLeod “Slik Stix” shifter, and you’ll need to come up with a
      shifter to console boot of some kind.
      Finally,
      you’ll need to either replace your factory speedometer with an electronic
      speedometer (more involved than it sounds because you lose things like turn
      signal indicators, etc. when the speedometer is removed – probably best done if
      you’re planning on going to replacement instruments), or an electronic to
      mechanical adapter like the Cable X.
      Other
      T56s
      The Viper T56 has the same gear ratios as
      the LS1 T56, but is supposed to have a higher torque
      rating. The Viper has an 8.25” input shaft, which would make swapping it into a
      first generation Camaro a bit tighter, as the farther back in the transmission
      tunnel you go, the narrower it gets. As mentioned above, you can swap input
      shafts with one from an LS1 T56, and solve the input shaft issue. Viper T56’s
      have a different speedometer connection than an LS1 T56 and a different shifter
      configuration, although a shifter meant for a
      2003-2004 Ford Cobra T56 will work on the Viper T56.
      The gear ratios for the T56s used in the GTO and Cadillac CT-V
      are - 2.97-1st, 2.07-2nd, 1.43- 3rd, 1.00-4th, 0.84-5th and 0.57-6th
      . The gear ratios for the T56’s used in the
      2005 SSR were 3.01-1 st,2.07-2nd, 1.43- 3rd, 1.00-4th, 0.84-5th and
      0.57-6th
      . I would expect (but have not
      personally confirmed) they both have the same input shaft length as the LS1
      T56.
      Colorado Springs
      Thats a good start for me
      THanks!
      TonyC@HP2
      Aug 2011
      North Platte,NE
      Whats up Tony? I can tell you that a Viper T56 has a 28" from the block shifter location. That is whats in my Dart and it works lovely since stock is 27".
      Colorado Springs
      Hey man. Good to know, but it may not help me out.
      I recently picked up a Quicktime bellhousing for small block mopar to LS T56. Since I haven't played with GM parts for nearly 20 years, I'm a bit out of the loop on their later model stuff, so I'm trying to understand options.
      TonyC@HP2
      Aug 2011
      North Platte,NE
