    Results 1 to 20 of 59
      We have a similar question for the engine in our new shop tool. If this is a street car, or will be driven primarily on the street, it is super tough to beat an FI rat motor. Cubic inches rule, period, on the street in terms of power versus cost, versus complexity. Power adders are really awesome, but add weight big time. In order to make things a bit nicer from a balance issue (weight), I'd recommend an alloy block, although I specifically haven't owned one before. The king of the hill in alloy blocks, based upon my recent research, is Donovan. GM and World both offer really nice looking stuff, but if you look at what the really serious races use, and recommend, Donovan is the winner.
      Anyway, case in point, the current shop mule has a nice stroker SBC (383). It has a lot of cam, a solid roller with 252 degrees duration at .050", and it is not a really "nice" street motor. It makes 10" of vacuum at idle, so vacumm assisted brakes are a no-go. I estimate power (when tuned right, which is not my personal strong suit), at about 525 - 550 HP. For the current car, we want 650-700 HP. Imagine how severe a small block would be? Eeek.
      I love the NASCAR motors, used, they are a terrific value. You'll hate them on the street, because of the rev factor (need to spin them), and more importantly, the dry sump oiling systems. Great for a track whore, not good for a driven car.
      Anyway, the thinkig currently is 540 ci, parts are readily available, Donovan block, wet sump, and likely (oh my) a hydraulic cam. Within a few pounds of a iron block/al head SBC, and WAY more friendly and reliable. Too much torque? Well. yes, that's always a possibilty, but if you have too much, there are two things you can do: improve the suspension, and learn to feed the throttle nicer.
      Go get 'em!
      Mark
