    Results 1 to 12 of 12
      Jul 2012
      Mooresville, NC
      LS3 ECM install in '69 camaro
      Just wanting to get some ideas and potentially pictures if available how different people have hidden their ECU's in LS swaps in '69 camaros. I am thinking about installing my computer under a custom console I will build, drill some holes in the tunnel and run the wires between tunnel and T-56 magnum tranny. Thoughts or advice? Thanks!!!!
      Metamora, Illinois
      I didn't hide mine, but I mounted the ecm on driver side of the radiator support and built a small bracket to hold the tcm and custom built fuse panel. The pics aren;t that great, but this was just the initial mock up. I should have it completely installed in the next week or so.
      Jul 2011
      NC
      I drilled a 2" hole rt under trans tunnel to route 3 connectors thru/under firewall. Mounting it up under dash. You will have to take topcap off connector to squeeze it thru. Using 2 piece grommet from summitt. Fuse box will be routed under fender to pass. Side & mounted on front inner fender hump- stock harness just long enough to keep it somewhat hidden!
      Josh
      "Schism"
      69 camaro
      Mar 2012
      Under my console
      Feb 2011
      dallas, tx
      anyone else have anymore pic? I don't want to mount it in the drivers side fender area like above because that is where my air filter will go. I guess i could always mount the ecu on the passanger side but the ac hoses might get in the way
      Dec 2012
      Which wiring harness are you using ? I used a PSI, and my ECU is mounted under the dash above the glove box, lots of room there
      Cheers
      Steve
      Build it right ... 'The 2nd Time !!'
      69' SS/RS X11 PRO-TOURING E-Force LS7 - SOLD
      2 Custom FJ40's -SOLD
      77' 911 Hotrod - SOLD
      'Killer Piggy' 73 FJ55
      67 Camaro - TBD
      Pensacola, FL
      I put them above or beside the glove box liner. Plenty of room and easy to get to if needed.
      Feb 2012
      Mine in a '68 Firebird prior to passenger fender install. Used an S-10 flat PCM mount with some mods. I have removed the plugs several times without issues. I have NOT tried removing the entire PCM yet. There IS a chance I might get it out, but PCM removal might require fender removal.
      This is the build thread for my car
      https://www.pro-touring.com/threads/...-Beak-Job-quot
      Feb 2011
      dallas, tx
      I'm using the gpmm controller kit. I guess what i need to do is route the wires thru the grommet and then see what extra length i have to mount the ecu and where. I don't have my ac kit installed yet to know what might interfer. Another thing i noticed with the controller kit is that the odb connector, mil wire, and ignition wire are up in front of the harness and if i want to keep the fuse box inside the car I'm going to have to reroute those by taking the harness apart some
      Jul 2013
      San Fernando Valley
      I mounted mine where the stock battery location is. I had a box made and mounted it on the underside and the fuse box on top.
      Check out post #24 of my build thread, it will make more sense. If you have any questions let me know. Hopefully I can help you out.
      https://www.pro-touring.com/threads/...toration/page2
      I put 'em on the back side of the passenger side inner fender. Nice and clean installation, but maintenance is a headache if you need to add a wire or debug a circuit.
      ​John Parsons
      Gainesville, GA
      I like to install the PCM above the glove box, under the dash, mounted to the cowl. In Jeremy Fletcher's build we mounted the PCM on a bracket off the glove box flange. (I cant find a pic) I hope this helps.
      Eric Evans
