    Results 1 to 20 of 28
      Jun 2010
      Deployed
      X-Factor Crossmember Concern!
      Gent,
      I'm using APT's X-factor crossmember (Aluminum) for my TKO 600 trans. When I installed it, I did notice it flexed a little when you put the weight of the transmission on it. Well Yesterday drove it for about 650 miles. I noticed when I ran over some dips in the freeway (about 60-75mph) the transmission hits the floor of the car. So I believe the forces of the up/down travel on the car caused the crossmember to flex up and down.
      My main concern is over time the crossmember to develop cracks and possible failure in the future.
      Has anyone else experience this?
      1970 Camaro/DSE build
      Jun 2010
      Deployed
      Just me???
      Or nobody has this X-member?
      Jan 2009
      Suisun City, Ca
      I notice the same thing with mine. My tranny doesn't hit the floor though. it's really weird when you hit a bump while holding the shifter.
      Michael Hunt
      Suisun City, CA
      Jan 2010
      Is anyone else having this issue. In a 67-69 Camaro big block, the shifter is offset to the right a 1/2" so I'm thinking if the trans. moves up and down much it will hit the bottom of the floor.
      Jun 2010
      Deployed
      Quote Originally Posted by tonyvol View Post
      I have a SBC and the shifter is whats hitting the floor on the bumps. The crossmember probably needs some braces so it doesnt flex. Right now its really just a flat piece of metal.
      Jun 2010
      Deployed
      Here is a picture of it.
      Lawrenceburg, TN
      thats a pretty thick piece, I would call the manufacture and ask them for bracing advice
      Feb 2007
      Tinley Park, IL
      Just thinking outside the box... is it possible your floor is flexing down and allowing contact with transmission?
      Nick ~
      1969 Cutlass
      Jan 2010
      I wonder if you have the old design. On the APT site it looks like these, unless the picture is wrong on the site. Looks to have more bracing.
      http://americanpowertrain.com/c-3137...minum-tko.html
      Jun 2010
      Deployed
      Thats the same picture they had on their site when I bought mine. As for the floor, no way. It can't flex like that, plus I feel the trans move up with my hand on the shifter. You have to see it to understand. Like I said earlier, when I installed it, putting the weight on the crossmember I saw it flex downward. Only make sense for it to spring up when the motion of the car pulls up on the trans.
      Jun 2010
      Deployed
      I'll contact them, just wanted to see if I'm alone here.
      Jan 2010
      Please keep us posted on what they say.
      Nov 2011
      Cookeville, TN
      Robby
      Did you contact anybody here at APT regarding your X-Factor? I am in the office today if you want to call just ask for Matt Graves. Also we test these crossmembers at 1000ft-lbs with a rotational torque test. We have had zero failures. I would not worry about the part breaking. In fact the old design had the braces. We took those out due to the increased strength of the new design. We use hot pressed 6061 aluminum. So they are very strong.
      Support
      American Powertrain
      Modern drive train technology for muscle cars
      Get your Shift Together
      America's #1 TREMEC Dealer
      Beach Park IL
      Strength and rigidity are two different things. A top fuel dragster flexes a LOT but they are strong enough.
      I have a similar design in a car, this one flexes way more than I want it to. I have no experience with the x-factor crossmember but it sounds like the OP is getting similar "bounce" from his crossmember.
      Donny
      Jun 2010
      Deployed
      Quote Originally Posted by American Powertrain View Post
      Robby
      I did call and I sent an Email through the website. I havent recieved a response.
      Batesville, IN
      Dumb question............If I'm thinking correctly, doesn't the x-member bolt to the back of the sub-frame in these cars? I'm just trying to think of other possible causes of the movement. What sub-frame bushings are you running? - - over bumps, could it be flexing the bushings enough to cause the back of the sub-frame to move? Do you have frame connectors?
      The x-member could very well be flexing and causing the issues, just thought I'd ask the question.
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      Stick a goPro camera under there and see what's moving around.
      Beach Park IL
      Or do what I did. Put car in air, grab tailshaft, push up and down, watch crossmember flex.
      Again for clarity, I do not have an APT x-factor crossmember but it is a very similar design.
      Donny
      Jun 2010
      Deployed
      Quote Originally Posted by wiedemab View Post
      I have global west solid body bushings and sub-frame connectors. The crossmember bolts on just like stock using the exisiting holes.
      Dec 2010
      Fredericksburg, VA.
      Is that a rubber or polyurethane transmission mount? It could also be the cause of the flex.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
