    Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 81 to 100 of 114
    1. #81
      Amazing project. What are the specs on the rotors? Are they custom or made for a particular car?
      Brian P
    2. #82
      Jun 2012
      Upstate SC
      Quote Originally Posted by protouring70 View Post
      looks very clean...awesome build!!!!
      Quote Originally Posted by BrianP View Post
      Thanks guys. The rotors are 14.5", also from a '09-'12 CTS-V. These are StopTech cryo treated. Factory rotors are dual-cast so they're lighter, but are supposed to be replaced every pad change. These should last longer and cost is pretty much the same.
    3. #83
      FL and Calif.
      Quote Originally Posted by theastronaut View Post
      Update on the valve covers. A few months ago I went to look at a set of VW wheels I found on craigslist and the guy turned out to be a normal car guy that works at a local machine/fab shop. Not the usual crazy craigslist seller... I mentioned the truck project and asked if they did CNC laser/plasma cutting and he said they could work in small projects. So I sent him a pattern of the valve cover flanges and he worked in two pair with a larger run of parts...
      [/URL]
      Awsome project and fresh ideas! How are you going to mount these on ls heads? Are you planning to make adpter plates or something else?
    4. #84
      Jun 2012
      Upstate SC
      Quote Originally Posted by Bowtie racing View Post
      I'll weld tabs inside the rocker box, then drill and tap them. No adapters that way.
    5. #85
      FL and Calif.
      This gets even better. Thank you for the info.
    6. #86
      Jun 2012
      Upstate SC
      No problem! Should be somewhat of a head-scratcher at shows with the hood popped.
    7. #87
      FL and Calif.
      Anything new on this super cool build?
    8. #88
      Jun 2012
      Upstate SC
      Not much, I ordered a pair of 18x9.5" Z06 replicas to get the front rolling. Also picked up a couple wheel spacers so I can get an idea of the offset I'll need when I order wheels for it.
    9. #89
      Jan 2015
      Charlotte, NC
      subscribed for sure!
    10. #90
      Beautiful project. That's a great idea on the Valve covers.
    11. #91
      May 2008
      Texas
      Gauges
      Love this build. I'm about to start on my 65 and I like to do a gauge cluster like yours will your friend do another that is if you don't mind coping you but with an 8000 rpm tach? Can't w to see more.
    12. #92
      Jun 2012
      Upstate SC
      I've had a lot going on lately so no big progress on the truck. The engines of both my daily drivers are currertly out and apart... it sucks driving the shop van all the time!! I should have one of them back together in a couple weeks; I'll get serious about getting the truck's rear end caught up to the front.
      I have been doing research and buying a few parts. I think I've narrowed down my rear axle choice to a 9" with Mark Stielow's/Detroit Speed's "floating" axle ends which accept C6 Vette hubs. This allows the full C6 rear brake assembly to be used including the parking brake. No pad knock-back and less maintence than a traditional floater. I've also decided on a three link with a full length panhard rod for the rear suspension. Seems to be the best for a mix of handling and forward bite off the line.
      Link to info on the Stielow/Detroid Speed axle ends:
      http://www.lateral-g.net/forums/show...&postcount=747
      I found a NOS hood repair panel.
      And I finally found a pair of Cibie fog/driving light covers. These were reproduced a few years ago but I missed out on the ones shipped to the US. These showed up on the German eBay so I had to grab them. I kinda like Cibie lights, if you didn't already notice.
      I picked up a set of 335/30-18" BF Goodrich G-Force KDW tires to get the truck rolling. They're not as sticky as I'd like for autocross or track days but they'll be perfect for the street. I knew they would be wide, but I wasn't expecting them to nearly come to the top of the S10's bed sides! I don't think they'll quite fit up front without relocating the sway bar mounts. We'll see. The 9.5" Vette roller wheels definitely won't work with these!
    13. #93
      Feb 2010
      El Segundo, CA
      Those are some impressive meats! Grip-central.
    14. #94
      May 2012
      just wow!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
    15. #95
      May 2013
      Texas
      Quote Originally Posted by woodside783 View Post
      Agreed. That dude is going to be a monster.
    16. #96
      Jun 2005
      Nice
      Anthony
      http://www.cardomain.com/ride/674663
      '71 Datsun 510, 2jz-gte (Supra TT) engine
      http://instagram.com/supra510
    17. #97
      Jan 2016
      Morehead City N.C.
      That is awesome. Cannot wait to see this one done.
    18. #98
      Nov 2010
      That is some serious rubber......
    19. #99
      Jun 2012
      Upstate SC
      I totally forgot to update the build thread here. No recent progress but here's where it's at.
      I got the front all together and rolling. I still need to box in the upper bag mounts and make caliper brackets. I picked up a pair of 12" wheels and they wouldn't quite clear so I'll drop back to 10.5" or 11" and run 315's instead of 335's. These are the 9.5" rims and 245 wide rollers, you can see that there is still a ton of room to go wider, especially once I notch the fender tops.
      Reproduction floor mats are finally being made again, and they're made really nicely. Picked one up from Fred's Truck Parts as soon as they had them in stock. I had been watching for a NOS or NORS for the last three years but they were pretty much unobtainable. Glad someone stepped up and started making a high quality reproduction.
    20. #100
      Jun 2012
      Upstate SC
      That catches up the truck progress to late last year. I haven't done anything with it this year since I'm saving up to build a garage/apartment. Ideally I'd like to build a double deep 3-4 car garage with a second floor apartment without going into debt so I've cut any spending on my car projects. I sold a few of my extra cars and bought a cheap car to daily so I could put more cash toward the garage/apartment project.
      Of course the go-fast bug is still alive and kicking so I didn't get just any "cheap daily". Now, I'm a Chevy guy and I've caught some grief from my friends for buying a "Ford", but technically it's a rebadged Mazda so I can own it with a clean conscience.
      For little more than the cost of a set of BFG Rival's for Goldilocks, I bought/built an '88 Ford Festiva that pulls a tad over 1g in near-freezing weather on 400 treadwear tires. The car is an absolute riot on an autocross course even though it only has 58 hp. It actually ran 2.4 seconds faster than my Miata on 300 treadwear tires at the same auto-X event; turned a 47.1 to the Miata's 49.5. It's not Pro-Touring, or cool like my old '64 VW, or the '87 Conquest TSi, or the '77 Celica Liftback I had but it gets me around while I'm saving up and I can still autocross it and have fun on the cheap.
      I'll start back on Goldilocks once the garage/apartment build is done. I've considered selling it to help fund the garage build but I can't really bring myself to get rid of it.
