    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 114
    1. #61
      Jul 2008
      Eads, TN.
      Incredible job you're doing on the truck!
      Amazing how many VW guys there are on here!
      My oval and my old panel with an Ecotec from a few years back...
      Jeff-
    2. #62
      Jun 2012
      Upstate SC
      Got to work on 'Locks Saturday. Got the rack and pinion bolted in and set the frame rails on 4x4" tubing. I want that to be the normal ride height, maybe slightly more if it scrapes too much. The lowest point on my '64 VW is 2.75 and it rarely bottoms out so I think 4" will be plenty.
      Mocked up the lower bag mount height with another 4x4" block, which leave the bag at 4.75". That's compressed too much so I'll move the top bag mount up a couple inches.
      Also built a stand to work on the caliper brackets. It looks like one of the bolt holes in the spindle will line up already, and I'll only have to make a bracket for the bottom holes.
      I had to plug a leak in my sister's TBSS tire so while it was off I checked to see how well 20's with a decent size sidewall would fit... way too tall. I don't want rubber band sidewalls so it looks like I'll be doing 18's.
      And speaking of wheels, I ran across this picture of CCW classics in the perfect color- brushed translucent bronze. They're three pieced forged so they're light and they're relatively inexpensive compared to most other three piece forged wheels.
    3. #63
      Jun 2012
      Upstate SC
      Quote Originally Posted by Ketzer View Post
      Jeff-
      Thanks Jeff, I remember seeing your bus at the show in Taccoa GA years ago, I think it was in grey primer back then. Probably 8-10 years ago. Love your VW's! I just changed wheels/tires on my '64, stock smoothies up front and widened smoothies on the back. Also built a set of widened 356 replicas for autocross.
    4. #64
      Jul 2008
      Eads, TN.
      Those CCWs in that color would look kicka$$!
      I remember the Taccoa show! Had a blast bringing the panel down and showing it off to the die-hards.
      Jeff-
    5. #65
      Jun 2012
      Upstate SC
      Jeff-
      That's the plan for the wheels, just like those. Step lip, brushed face with a translucent bronze tint clear. Maybe around 5-10% flattener in the clear to knock down the shine a little. Think they'd compliment the paint color perfectly.
      The Toccoa show was my favorite; was going to it before I even got my drivers license! The fairgrounds were hard to deal with though so Lee couldn't keep doing the show there.
    6. #66
      Jun 2012
      Upstate SC
      Chopped the crossmember today to raise the bag mount area. I need to get some plate and 10" pipe to box the area in. At this point I've realized I would have been better off to buy a No Limit WideRide crossmember...
      2" cut out.
      7" tall now. That'll shrink a little once I plate the mounting pad but it's a major improvement!
    7. #67
      Nov 2010
      Great job...
    8. #68
      Jun 2012
      Upstate SC
      Got an update on the speedo lens today!! Won't be long til the cluster is finished.
    9. #69
      Jul 2008
      Eads, TN.
      Quote Originally Posted by theastronaut View Post
      Very familiar! I often don't see the easy until I'm waist deep in the impossible. If only I could figure everything out the first go-around, my wagon would have been done years ago....
      Jeff-
    10. #70
      Jun 2012
      Upstate SC
      Made a little bit of progress, mostly just buying parts. Been picking up NOS parts when I can find them and the price isn't unreasonable. So far found a pair of '66 Fawn armrests, interior mirror mount, and an anodized grill. Another find was a pair of NOS offset stud mirror heads. They're not GM but are identical. I also bought a pair of NOS chrome bumper guards that had a fair amount of shelf wear but I couldn't bring myself to use them for what I have in mind...
      So instead I bought a pair of used guards to cut up. Wanting to shorten them a few inches to take some of their bulk away, always thought that they just looked to tall to fit the proportions of these trucks.
    11. #71
      Jun 2012
      Upstate SC
      I also bought a set of Porterbuilt 1" forward and 1" narrowed A-arms and QA1 .500" taller upper ball joints. I mocked up the suspension and measured the camber gain over one inch and came up with 1.61* per inch. Rob at No Limit posted that stock is .86* and their Wide-Ride suspension has 1.56* per inch.
      I dropped off one of the spindles and calipers at a local machine shop to have caliper brackets built. I'll have a few extra sets made if anyone is interested in doing the CTS-V brake swap.
    12. #72
      NC
      Awesome work, everything looks amazing.
      Your attention to detail is stellar and that wheel chose is perfect.
    13. #73
      Jun 2012
      Upstate SC
      Quote Originally Posted by Tig View Post
      Thanks!! I'm looking at another CCW wheel now, same spoke design but the lug nut/center cap area is recessed for more caliper clearance. I like the recessed look better too. I may have the lips anodized to match the factory anodized side trim and grill, and they'd be less upkeep than polished lips.
    14. #74
      Mar 2000
      San Diego, CA
      Man, great build and truck. Love the intake and carb setup. Totally going to be sweet!
      Mike Schwartz aka chevymike
      1955 Chevy 210 Wagon
      1965 Chevy C10 Panel Truck
      1972 Chevy El Camino
    15. #75
      Jun 2012
      Upstate SC
      Quote Originally Posted by chevymike View Post
      Thanks Mike!!
    16. #76
      Jun 2012
      Upstate SC
      Update on the valve covers. A few months ago I went to look at a set of VW wheels I found on craigslist and the guy turned out to be a normal car guy that works at a local machine/fab shop. Not the usual crazy craigslist seller... I mentioned the truck project and asked if they did CNC laser/plasma cutting and he said they could work in small projects. So I sent him a pattern of the valve cover flanges and he worked in two pair with a larger run of parts.
      I'll have to do some minor reshaping on the end that I started on to get them lined up 100% but it's pretty close already. I have another pair of valve covers in good shape that I'll probably use. I'm thinking about shortening them maybe 3/4" inch from the first one I modified- not sure about that yet. Also thinking about making another pair from 327 car valve covers.
    17. #77
      Apr 2007
      Minneapolis, MN
      Really cool idea for the valve covers. Very original. Love the truck
    18. #78
      Jun 2012
      Upstate SC
      Quote Originally Posted by 68byrd View Post
      Thanks!!
    19. #79
      Jun 2012
      Upstate SC
      Jul 2004
      Braselton, Ga.
      The 160 mph speedo lens and background decal are finished.
      looks very clean...awesome build!!!!
