Results 1 to 20 of 76
Thread: 1971 Pontiac Lemans Convertible
- Nov 2011
- Springfield, OH
- 58
I have been lurking on this forum for almost a year now learning an amazing amount of information from all of you and your impressive builds. Thank you for making the effort to publish your experiences, it has been a huge help to me.
To show my appreciation to the Pro Touring community I am starting this build thread for my project to share what I have learned and accomplished with the hope that others can learn from me.
First, some background. I am 52 years old with a mechanical engineering degree. I worked at the Boeing airplane factories for many years where I learned a lot about airplane manufacturing, materials, fasteners, etc. I have also enjoyed my woodworking hobby for many years, for the last several years I turned that into a cabinet-making business. So I am good with my hands making things and figuring things out.
I have had two car projects in the past. The first during high school was a 1978 Plymouth Volare with a V8 and four speed (I know, sounds lame now but Dad worked for Chrysler and I ordered it new with the features I wanted, paid cash saved from after school jobs). I did the usually hot rod stuff, four barrel carb, headers/exhaust, wheels tires, etc. Learned a lot about cars from this effort, especially from my mistakes! Second car was several years later, bought a 1972 Datsun 240Z where I changed carbs to a Holley four barrel, reupholstered interior to black and did a crude red paint job.
Fast forward to last year; kids are teenagers, have time/money/place to do another car project, and divorced so no one to justify spending money to. My 18 year old son and I got to watching Overhaulin episodes on Netflix last year, he would keep asking me if we could do something like that. I initially wasn't real crazy about it, but the more I thought about it the more I liked the idea.
So last summer went searching for a project candidate. Looked for mostly GM (easier to get parts), and something cheap to conserve other money for upgrades. I ended up buying a 1971 Pontiac Lemans convertible. Previous owner and his dad bought it in pieces 10 years ago, it sat in their barn untouched until I bought it. He was asking $2500, I paid $2000. He said "floors are solid", I soon found out as many of you have what a misused phrase that is . . . Being a midwest car it has rust issues, some I was aware of when I bought it, some discovered later.
Pictures below show us bringing it home:
I also got bumpers, front sheet metal, two sets of doors, seats, most of the exterior trim, etc.
Plan is to do a mild Pro-Touring build with LS1 power, and hopefully get my kids involved now and then so they can learn about cars with me.
We started this build last fall and have worked on it steadily since then making a significant amount of progress. I thought I would post an update every few days covering all of my progress made between then and now and then hopefully keep it updated. I will try to include details and part numbers as much as possible.
Thanks for reading.
06-14-2012 #2
- Nov 2011
- Springfield, OH
- 58
Deconstruction started as soon as we got it home. I took the advice of others and tagged and bagged removed parts and took pictures as much as possible.
Since it's a convertible I added bracing to the interior to keep it folding up like a taco while it was off the frame. Since my welding skills were zero at that point and steel can be a little pricey I looked for materials that might work and come upon electrical conduit which is relatively cheap and easy to work with. I attached these to the car and to each other with 5/16" bolts. I tried to triangulate the bracing as much as possible to keep the body from flexing too much, it seemed to work really well and kept it rigid for months.
With that done I was ready to remove the body. Removing the body bolts proved to be quite the chore due to rust, I think only one or two came out without damage. Some snapped in the middle, some the welded cage broke off. Those bolts I wasn't able to get off I just cut through. I tried soaking them with PB blaster without much luck. Several of them had rusted to the point they were less than half their original diameter. Once the body bolts were out it was a slow and careful process using wood and concrete blocks and a floor jack to raise the body high enough to roll the frame out.
To sandblast the frame and keep the mess outside I rolled it outside in front of my shop. I bought an Eastwood blaster which I was very happy with. The seller of the car also sold me his old 80 gallon air compressor which was very helpful supplying the large quantities or air required by the blaster.
The frame was in pretty good shape, mostly surface rust with the exception of some rusting out around three body mount holes. I fixed that with the repair "washers" some of the restoration companies sell.
To finish the blasting I removed all of the suspension, brakes, steering, and remaining hardware and tubing. To refinish the frame I used all Eastwood products; Rust Convertor first, then Rust Encapsulator, then two coats of epoxy primer and two coats of their epoxy chassis paint. Internal Frame Coating was sprayed on the inside of the frame. This picture shows the frame refinished and the caster supports I made to make moving the bare frame around easier.
01-08-2017 #3
- Aug 2012
- Texas
- 9
