    Page 29 of 30 FirstFirst ... 19 24 25 26 27 28 29 30 LastLast
    Results 561 to 580 of 593
    1. #561
      Dec 2010
      Just do the baseball bat, maybe with the addition of some torch heat for motivation. You should be able to get enough space to clear the tires under some lateral axle squirm this way--aim for at least 1/4" inch outside the sidewall. Cutting of the inner fender will only help (yet add additional work, but that's why you're here) . . .
    2. #562
      Chicago
      I decided to build my own front flares, should I do small rear flares?
      Yes please as I would love to see how they look
      marty-mj
    3. #563
      McKinney, TX
      See if this works
      89 Mustang "Box Wine"
    4. #564
      Seems to be working. Love the gold wheels. What color are you planning for the car?
    5. #565
      McKinney, TX
      And now they're gone! Thinking a light metallic blue similar to the original Silver Blue Poly it came in.
    6. #566
      Jan 2016
      Chino Valley, AZ
      that with the gold wheels will be KILLER.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
    7. #567
      I have no idea what is going on with the images. They were there...maybe post in the forum help section and Larry can address it?
      I agree that blue paint with the gold wheels will look great.
    8. #568
      McKinney, TX
    9. #569
      Mar 2018
      la mesa, CA
      UGH your still in picture ban land
      Follow my Instagram
      And my build on here
      check out Opentracker Racing Products
    10. #570
      McKinney, TX
      Quote Originally Posted by Project Bike Truck View Post
      Fail!! Lol ugh
    11. #571
      McKinney, TX
      Update: all 4 flares are built and about 60-70% body worked. The MS2 ECU died so I replaced it (after much troubleshooting) with a Microsquirt unit that plugged right in. I've been driving it and finding out what all is wrong with it: turbo oil drain isn't draining properly causing oil in the charge pipe, throttle cable has an over centering issue, trans only shifts 1-2 so may have to upgrade my homemade bracketry to a true kit, turn signal switch **** the bed and is causing all sorts of weird lighting issues and I need to wire up the flex sensor and fan control to the ECU. Its a blast to drive regardless and gets a lot of attention, the old folks on the street behind me give me the evil eye every time I drive by. It sounds like a damn 747
    12. #572
      Sep 2018
      I can relate.
      I had trouble even cranking it in my garage and backing it out of the driveway(when mine was running), I felt like I was rattling the neighbors windows!
      One neighbor is not pleased, but it now pays to be the president of the homeowners association. Ha!
    13. #573
      Mar 2018
      la mesa, CA
      Could it not be the drain but the fact its got too much pressure and pushing oil past the seals into the charge system?
      as for the rest if the stuff, Damn Gremlins. I am scared of the trouble shooting days.
      Follow my Instagram
    14. #574
      McKinney, TX
      I replaced the turn signal switch, fixed a couple broken 50 year old wires and now my turn signals and brake lights are working again. I built a new throttle bracket to pull the cable straight, I haven't fixed the trans yet as I'm not sure what's going on with it. I started pulling some of the turbo kit off to fix some clearance and fitment issue, if I ever have to pull the down pipe it is almost impossible to get back in place and the turbo has a slight "nose down" fitment. I did upload a quick video before pulling it apart.
    15. #575
      Sep 2018
      Wow that sounds great!
      I’d love to hear more about your turbo set up...
      Who’s is it? Pics?
    16. #576
      McKinney, TX
      Quote Originally Posted by mikeyhunts View Post
      Who’s is it? Pics?
      Its a kit I built, T-70 turbo, hedman shorties flipped, 3.5" down pipe and 4" exhaust to a Dynatech muffler
    17. #577
      Feb 2011
      Indpls, IN
      I don't feel like reading through all the thread right now. But, If you are using a AOD transmission? The AOD has a pretty goofy shift sequence. I put a 5.0 and AOD in my 66 F100, I'm not real happy how it shifts. It skips 2nd gear unless you manually shift it in a certain sequence. If you do have a AOD do some googling, you will find info. I have bought a new valve body form Silver Fox performance. Several people recommended him., it took awhile to get it as he is a 1 man show.
      But, I haven't installed it it.
      If you do have a AOD, hope this helps you or someone else.
    18. #578
      McKinney, TX
      Quote Originally Posted by Jetfixr320 View Post
      I’m using a 4r70w but yea maybe someone else can benefit. Thanks!
    19. #579
      The Netherlands
      Country Flag: Netherlands
      Sounds awesome!
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    20. #580
      Oct 2007
      Camas, WA
      That does sound great!
