    Results 1 to 13 of 13
      Dallas/Fort Worth, TX
      Does your LS1 overheat too?
      I have a '69 Camaro with a 2002 LS1, stock except for some headers and the computer tune. I've also got an aluminum radiator, a 160-degree thermostat, and electric fans that come on at 160. Everything is great as long at the RPMs are about 1000 or higher...the temp stays at 180, even in the Texas heat.
      The problem is at idle the temp starts to climb and will go over 250. No drive-thru windows for me! It's like the stock water pump doesn't have enough flow at idle to get the hot water into the radiator. I can put the car into neutral and rev the engine to 1500 or so and the water temp cools off.
      Has anyone else here experienced this problem? I know they make an electric water pump but I was hoping there was a better solution.
      Steve
