      Feb 2011
      Pinion Angle '69 Camaro?
      I'm building a custom support for my T56 Magnum/LS3 in a '69 camaro. I have a lot of flexibility as to the pinion angle, and I'm curious how people set it up. Since I also put in a DSE quadralink in the rear, it is easy to set up the equal/opposite relationship but I don't know if there is some optimum value I should be shooting for.
      thanks for the help.
      Adam
      Jan 2012
      Alexandria, Mn
      From what i've learned/heard. Its always best for the pinion angles to match at 3 degrees. Thats when the u-joints are working best.
      Quote Originally Posted by Chris02rex View Post
      First of all we need to define what angles we are talking about. The critical angles to consider are the front and rear operating angles. The front operating angle is defined as the angle between the transmission output shaft and the driveshaft. The rear operating angle is the angle between the pinion gear and the driveshaft. The working angles must be equal and opposite and also as small as possible, but not zero, with a maximum of 3 degrees, for our type of car.
      san diego
      And the key word is "working".
      Example for a drag car you want the WORKING angle to be equal and opposite during the highest point of acceleration, the highest load on the u-joints.
      Depending on rear suspension geometry and A/S values every car will act differently under acceleration. Some squat and some lift. HAH, that came out weird.....
      Oct 2011
      exactly...this is all true.
      Feb 2011
      Thanks Everyone. Very helpful for the new guy!
