Results 1 to 16 of 16
Thread: Busted a Valve Spring
07-12-2005 #1
- Aug 2004
- Fenton, MO
- 80
Ok heres the deal these springs have 40,000 miles on them, they have always been run on the same head, and always matched with the same Cam.
Comp Cam 274XE and Comp Springs 981
I was on my way home from Amarillo, TX headed for St. Louis, MO and around Stroud, OK somewhere on the highway I busted the valve spring cause when I let off the gas to stop at a gas station it just died and wouldent idle. Thats when I found the #7 ex valve was in 3 pieces.
Now these have seen maybe 150 passes at the strip, cruise RPM's from 2400-3500, and never reved over 5800 RPM.... So what happen? they were checked for correct install height and coil bind at time of install. So just a bad spring? Luckilly it was a clean break in both spots and as you can see the valve didnt drop. Could have driven almost 100 miles with it busted.
Should I replace them with the same comp sorings or a similar spec spring from another mfg?
