    Results 1 to 19 of 19
      Des Moines, IA
      Coil Over Spring Rate:
      You can choose whatever spring rate you'd like to put on the shocks. You just have to tell us what you want.
      You can use our spring rate calculator to help you through this:
      http://www.ridetech.com/tech/spring-rate-calculator/
      Coil Over or Shockwave:
      As Bret stated the coil over and the Shockwave use the exact same shock. So the only difference is the spring. Air springs are much more progressive than the traditional coil spring, and therefore require a slightly different tuning approach.
      I personally love the air springs on our 66 Chevelle. The cars takes a set and transitions so nicely I wouldn't change a thing (though of course we have tested just about everything on that car, including the coil overs and a kitchen sink)
