    Results 1 to 9 of 9
      Frontrunner questions.
      What does the frontrunner come with, or what else do I need? Cost?
      I think it does come with the compressor, but no ps pump. Does it come with the alternator?
      What would I need as far as the alternator and ps pump? I think I'd have to run a remote resivore for the ps is that correct?
      Starting to sound expensive, but it would be nice.
      I'm just looking at the base model, no polish or anything.
      Mar 2003
      Kirkland, WA
      It comes with the alternator, but not the PS pump. It will fit models with an integral resevoir, or you can run the remote one if you want.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by Rileys68Camaro
      What would I need as far as the alternator and ps pump? I think I'd have to run a remote reservoir for the ps is that correct?
      They are expensive but the polished option is only $50 extra or so.
      My power steering pump came with an integral reservoir and was purchased from DSE.
      SoCal
      Yes, it's expensive but it's so cool.... I love the way it pulls the accessories in close to the engine and is clean... The compressor is very small. Only one belt to worry about
      So the only accesory componant not included is the ps pump and resivore, correct?
      Which power steering pump would I need?
      Mar 2003
      Kirkland, WA
      I got mine from DSE.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
      When you were putting yours together, you know the dowel to the belt tensioner, did you have to "press fit it". Or were you able to just push it in with your finger. Mine kept on falling right in.
      Mar 2003
      Kirkland, WA
      Mine just pushed in with a finger. I plan on locktiteing it in there when I do the final assembly.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
      Jackson, Michigan
      It comes with a stewart high volume water pump standard... AC compressor is a option. As is the provision for the power steering pump. I think hard coat is standard and polish is a option.
