Results 1 to 20 of 26
01-18-2012 #1
Getting started with Aerodynamics
Hi Guys, I'm interested in cleaning up the aerodynamics on my Monte Carlo. I've read through several threads including the links Ash posted and learned some, but I still have some questions. After my reading I think there are 4 areas to consider working with.
My first step will be to perform the yarn puff test. This will most likely have to wait a while while i work a few other things out, but in the meantime I wanted to get as much information as possible. As far as the 4 area's go;
- Front air dam. SO far my reading has not fully defined how the front air dam affect my particular car. I was thinking that a splitter may help but I am not sure. Instead I was thinking that a horizontal lip attached the the bottom lip of the air dam would be the way to go. Would this be as effective? Also, I have a fiberglass nose on the car. there is a large open space behind the air dam between it and the radiator. There is also a small spoiler mounted in this area. Does anyone really know it's purpose and how effective it is? I was thinking of installing a panel across this opening to smooth this area out.
- The hood, I have a Harwood Pro Touring hood on the car. The front of the scoop is open and I plan on ducting this to the intake to create a Ram Air effect. The rear of the scoop by the cowl is closed in. It is approx 4" tall and I was thinking of opening this area up in order to help vent the engine bay air. Right now any air entering the engine bay through the grill can only vent down and under the car which I think is really not desirable.
- My car is a Notchback and although I have not tested it yet I think that the area behind the rear window and the trunk lid may be a massive turbulent zone. I am thinking that vortex generators may help in this area, thoughts?
- Lastly the rear of the car. The rear of the car must be a huge low pressure zone. I say this because it is always filthy after driving. There are several rear spoilers available for the Monte. I currently have the standard upright spoiler, but there are extended spoilers and laydown spoilers available. How does spoiler design affect airflow in the rear of the car? Is a diffuser something I should consider?
I would like to learn more about aero so if anyone knows of a good book on the subject I would appreciate the information.
1986 Monte SS, 427 sbc, Victor E manifold, FAST TB, FAST XFI, T56 6spd, Moser M9 rear 3:70, SC&C G5, Spohn lowers, Pole Position Uppers, Alston Coil Overs, Pirelli all around
