      Nov 2004
      295/45-18" NITTOS
      Where can I find a source for a pair used /worn out 295/45- 18" Nittos 555's for mock up use only? All that's needed is that they hold air. Thanks
      Prescott Arizona
      Hey dude, try the classifieds on a Ford Lightning forum. That's a stock size for some years. Hope the wheels are working out OK.
      Brian D
      Snotty Bimmer driver.
      dayton ohio
      try the ford dealer and or tire dealers, look behind the building after hours or call and ask. they should have some. you might have to go to the svt specific dealers though. they are the stock size on 99 and newer i think.
      POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
      Nov 2004
      Brian the wheels should work fine, I still need to make some mock up spacers to get the correct rear spacing. Thanks for the tire info.
      genbu3,
      Thanks for the info I'll check with some local dealers to see what I can dig up.
      The Nittos are nice tires. I am running those on the back of my GTO.
      Nov 2004
      Thanks for the feedback Andrew. I'm doing some mock up trials before I order the combo and hopefully I'll get something going by the first of this next year.
      Gerald
