      LS1 flywheel spacer/long pilot
      OK, have an LS2,a first year T56 for an LT1, and an 84 elCamino. Bought the T56 to go behind a 383SBC, but changed direction. First year T56 have a different ratio set than the later LT1/LSX ratios,so the typical input shaft/mid plate/bellhousing change to convert to LS won't work due to the different tooth count on the input shaft.
      My understanding is that the input shaft is too short to use the LT1 box on an LS motor. Does anyone know what doesn't engage? Does the clutch slip off the input shaft splines? Does the nose of the input shaft not engage the pilot bearing?
      If the clutch doesn't engage the splines fully, has anyone investigated a special clutch that has the spline hub located further car aft, or the flex plate spacer used for putting a T400 behind an LS motor? ? If the input shaft doesn't engage the pilot bearing deep enough, could one use a longer roller bearing, or turn a bush that would provide adequate support?
      Reason I'm asking is,I saw a deal on you tube,and since it was on the internet,it must be true.Couple guys were screwing a muncie to an LS motor,using an early 200X flywheel and partially installing the pilot bearing.
      http://www.youtube.com/watch?v=RCGl5HbrUeE
      comments please
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      I came from that same situation about 2-3 months ago. Your best option is to sell the 93 T56 and buy a good used LS T56. The problem is that no one wants the 93 version because of the odd gearing and it's not as strong as the 94+ units (again due to gearing). For the record, I would never partially install a pilot bearing - it's only asking for trouble. Remember that the input shaft can be spinning as fast as about 6500 RPM. Just imagine what would happen if the pilot shifts forward or breaks. The shaft will be allowed to run unsupported which could really do some damage not only to your car but to you as well. Remember the clutch is right down next to your legs. At 6000+ RPM there will be shrapnel flying everywhere. Just for safety's sake alone don't try it...
      GeoffP
      68 Camaro - LS1/T-56
      Dec 2010
      St Louis
      Check over at LS1tech conversions. It looks like the LT1 T56 is about the only trans that's nearly impossible to get to work with an LS motor.
      For the record, I've done the muncie, T10, Richmond trans/LSx motors.
      He made 2 mistakes in the video;
      1) Use an LS7 pilot bearing. It rides in the outer crank flange and the input shaft seats fully into it.
      2) The truck bell housing opening for the bearing retainer is larger than the car version. A car muncie wont fit tightly in the truck bell housing like it should. There are adapters you can buy. A 621 housing will work.
      Quote Originally Posted by garys 68 View Post
      I agree with what Gary said 100%.
      Geoff,
      Using a longer pilot is not really a big deal. Keep in mind that the input and the flywheel are turning at the same speed under power. The only time the input is actually spinning inside the pilot bearing is if there is a mismatch in speed between the engine and input shaft, like when shifting and if sitting at the light with the trans in gear and the clutch pedal pressed.
      Greg,
      The biggest issue with the LT1 style T56 is that the short input doesn't offer much room inside the bellhousing for a clutch. For this reason the LT1 clutch used a pull style spring. The LS1 T56 has more room and thus can use the push style TOB arrangement. As it's been said, I would sell the LT1 T56 and get a LS T56.
      Nov 2004
      Colorado
      What about a LS2 GTO M12 input shaft? The GTO has the same 1-4 gear ratios as the 93 LT1, will that input work? Just a thought.
      Andrew, I totally agree. A longer pilot bearing that is designed for the application is completely acceptable. I was just stating that partially installing a standard pilot bearing is not acceptable and is asking for trouble.
      GeoffP
