    Results 1 to 20 of 98
      Feb 2006
      Enumclaw, WA
      Project LSxChevelle (2nd try)
      Well I bought a 70 about 2 months ago for $1,000. Original A/C car with power front disc, buckets, auto console and the owner swapped a 12 bolt in unknowingly (to fix his broke 10 bolt). Car was too rough for me....needed both quarters, inner qtrs, trunk filler panel, rear tail panel, all new front. I bought a title with parts!
      I was in it $1,150 and sold car for $800 (-$350) but....
      $300 for 12 bolt to 10 bolt swap with uncle
      $300 for buckets
      Still have console for sale...
      Ok...didn't lose $$
      So this weekend I bought a 72 (have to swap clip!) but I was able to drive it home for $3900. (came with an original SS hood too)
      Short term plan:
      Swap clip to 'make it a 70' and get body straight in primer with 70 bumpers (gloss black including headlight trim rings)
      Have a 5.3 with good crank so I am going to get a stock set of rod/pistons, cam, good used LS6 heads, and a carb setup
      Long term:
      Drivetrain/suspension-
      408CI LS
      Positive atmospheric pressure via Whipple 4.0L (considering other options including TT)
      T56
      Art Morrison GT-Sport chassis
      Kore3 C6 Z06 front brake kit for C6 hub
      Kore3 C6 Z06 rear brake kit w/ parking brake for 9"
      Appearance/Interior-
      Anvil carbon hood (painted with some revealed)
      Black or body colored bumpers
      Carbon diffuser
      Carbon front lip
      Shaved drip rails
      5th Gen Camaro seats? Front/Rear
      SS Dash wrapped w/ matching fabric
      Autometer gauges and built in touchscreen (linked to car pc and audio system)
      Jason
      1970 Chevelle Pro-Touring Project
      Plans- 6.0L H/C (TT later), T56, UMI suspension, Kore3 C6 Z06 brakes, and lots more....
      Feb 2006
      Enumclaw, WA
Size:  233.1 KBHere are a few pics...
      Oct 2011
      Peru, IN
      Subscribed.. Good luck!
      Building a GN to carve corners and travel long distances. *inprogress* Ridetech Coil-Over Tru-Turn Suspension, custom paint by child's tricycle handle, Baer Brakes, 6152turbo, 2800stall, Lonnie Diers Transmission, factory installed T-Top water leak, Casper custom harness, hanging on for dear life vacuum line setup, homebrew ported heads, Translator2, AEM TruBoost control, Good looks by GM, oil and gas by fossils, slightly understanding wife mod, Praise Jesus it runs installation, and Baer Brakes for the 'whoa.' R.I.P. Powermaster 1987-2004.
      Oct 2011
      Central Ohio
      I like the '72 front end. The '70 is nice too, but I guess I always liked the red headed step child. Very close to everything else, just not loved as much. ( like a Lemans vs a GTO) Good Luck.
      Jul 2008
      ohio
      wow looks to be in great shape
      NJ/PA
      Much better the second time around. Im going to have to say that I too like the look of the later year chevelle. My brother has a 70, but so does everyone else. Just food for thought. Either way much better pick up this time around. Looking forward too see where this goes.
      Feb 2006
      Idaho Falls, Id
      I can't believe you bought a 70 Chevelle for $1,000, even if it were a pile of rust.
      Looking forward to seeing what you do with the 72
      Traven
      Feb 2006
      Enumclaw, WA
      Quote Originally Posted by 70lsxswap View Post
      nice
      Thanks but is that all you have to say on everyones thread? lol
      Snohomish, Washington
      Quote Originally Posted by LSxChevelle View Post
      Hey, he did post 2 different things, "Very nice" and a "Man that sucks!"
      Matt
      Feb 2006
      Enumclaw, WA
      Well I saw a CL ad for misc LS parts and offered $50 for LS7 lifters...well I gave hime $500 and got a LS1 longblock with a window on the pass side.
      Two of the lifters dont want to come out...I told him and he is going to give me a full stock set.
      So the good...
      -ARP rod bolts
      -Comp XE-R cam .595"/.598" 112 LSA and 232/234 duration @ .50" lift
      -ARP head bolts
      -Stock 853 heads w/ sodium filled valves and Comp 918 springs (not on when blew up)
      -ARP head bolts
      -Water pump, front/rear covers, and F-Body pan (for sale)
      So I will see if my 5.3 will bore to 3.898" and swap the 7 good rods/pistons to it and I have another stock piston/rod at home.
      All I need now is to figure out acc items and get the intake/MSD ignition box.
      Jul 2008
      Ft. Worth, TX
      I like th 72 front clip also, I guess I'm biased since I have a 71. HA. Sounds like a cool project. I swaped a 408 LS3 into mine, so if you need any tips give me a shout.
      Feb 2006
      Enumclaw, WA
      Thanks, plan is to run the LH8 pan since it's not lowered on the temp motor. I bought the $30 ebay LS swap plates so hopefull they set it in the right place. Also need to figure out accessories.
      Jul 2008
      Ft. Worth, TX
      I tried just about all the pans and the fbody fit the best for me. I am using edlebrock motor plates. Nothing is a bolt in swap on these.
      Plantation, FL
      $1000 for any 1970 car is awesome. But, for that car that was a steal. Good luck on the project.
      Steve
      69 Camaro
      Feb 2006
      Enumclaw, WA
      Well tonight I'm picking up a LS6 longblock for a steal! A friend w/ a 88 Monte has had a LS1, LS6, and now a LS7... I called for some motor input and he said he still had the LS6 torn apart. (Been like that for 4 yrs) He bought it a 9k miles and maybe put 15k on it before a rocker failed. He tore apart and found every needle in good shape and no damage but already had a LS7 crate on order... Comes with stock Z06 cam and I think good springs (had a big cam). No valve covers...
      So how does $350 sound?? :D
      Will have it on the engine stand tonight to start assembly. Going to use the ARP rod bolts, ARP head bolts, and cam from other LS1 I bought. Also plan to paint shortblock Chev orange to make it somewhat old school.
      Charlotte
      Your buddy with the LS7 over on LS1tech?
      2014 Chevy SS LS3 / 4 Door
      Feb 2006
      Enumclaw, WA
      Yea...great guy.
      Jul 2008
      Ft. Worth, TX
      Sounds like a good deal!
      Feb 2006
      Enumclaw, WA
      Ok, so not a LS6...guess I got confused in our conversation. But I do have a good 99 LS1 w/ low miles. Tonight I will clean the block up assemble shortblock. Going to pick up some VHT Chevy Orange engine paint as well.
      Feb 2006
      Enumclaw, WA
      Well you can definately tell its a low mileage motor. Bearings looked beautiful but came with a new set of Clevites so I went with them.Name:  IMAG0005.jpg
Size:  165.7 KBName:  IMAG0006.jpg
Size:  90.7 KBName:  IMAG0008.jpg
Size:  98.1 KBName:  IMAG0010.jpg
