    Results 41 to 60 of 98
    1. #41
      Feb 2006
      Enumclaw, WA
      Look below the motor mount for the window in the block...just a junk block I'm using for test fit.
      1970 Chevelle Pro-Touring Project
      Plans- 6.0L H/C (TT later), T56, UMI suspension, Kore3 C6 Z06 brakes, and lots more....
    2. #42
      Feb 2006
      Enumclaw, WA
      Guess I need to get out in the garage and starting assembling the puzzle...
      Had heads resurfaced (.003"-.004"), cleaned, valves lapped, new seals, and assembled with my PRC duals.
    3. #43
      NJ/PA
      Nice man. I like where this is going. Keep plugging away..
      67 Camaro - LSX454 w/ T56 Magnum
    4. #44
      Feb 2006
      Enumclaw, WA
      These headers look better...
    5. #45
      Feb 2006
      Enumclaw, WA
      Not sure what the angle is but it looks good so far with minimal cutting.
      Accessories look great against the steering box.
    6. #46
      Feb 2006
      Enumclaw, WA
      Took about 2 hours before it finally started crinkle-ing... Turned out pretty good I think.
    7. #47
      Mar 2012
      keep th updates coming... i love a good chevelle build
    8. #48
      Feb 2006
      Enumclaw, WA
      The updates should start being with more serious progress.
      Tanks, Inc pump, Vette FPR, and lines shipped today. Have all engines parts except cam and air intake. Ordering those thurs as well as the trunion upgrade kit for the stock rockers.
      Checking the trans angle tomorrow and assembling longblock.
    9. #49
      Jun 2008
      Western Washington
      Nice looking build!
      What are your plans to change the TR6060 to a splined slider output shaft (T56 Magnum) versus the rag joint?
      I'm curious since I want to do the same thing, since TR6060's are MUCH cheaper and more available used than the T56 Magnum.
      "Step Brothers"
      Pro Toured 95 Pontiac Trans Am (Green Dragon)
      Full Frame Build 69 Camaro (Night Hawk)
      -Luca Z
    10. #50
      Feb 2006
      Enumclaw, WA
      Hey man...I've always seen you pop up on here or Tech. What area of WA you in?
      I'm not changing over to a splined slide output...just getting this custom driveshaft. CV joint 3 bolt front and standard u joint at rear...
    11. #51
      Jun 2008
      Western Washington
      I am in lovely Bremerton!
      Is that from the Drive Shaft Shop? What HP is that type of joint good to? It looks like they basically move the splined slider to the DS? Does that DS allow you to take the black rubber isolator off the output of the TR6060, and just bolt up the slider adapter potion? I am just very interested since I would love to not have to convert a TR6060 if I don't have to.
      Also, how much more is that DS than a "normal" Aluminum DS?
      "Step Brothers"
      -Luca Z
    12. #52
      Jul 2008
      Ft. Worth, TX
      Project LSxChevelle (2nd try)
      Very interesting driveshaft. I would also like to know more about it. With the tr6060 in the car does the cv portion of the driveshaft hit the tunnel?
    13. #53
      Feb 2006
      Enumclaw, WA
      Driveshaft runs about $900 and is rated for 900HP. Not sure about tunnel fitment.
    14. #54
      Feb 2006
      Enumclaw, WA
      Well I started the engine build...mocked it up since I can't install heads until the lifter trays show up in 2 days. I also found a issue that many others seem to have. Lower half of can bearings are showing copper...but after much reading it is normal and even shows on some new crate motors.
    15. #55
      Feb 2006
      Enumclaw, WA
      Well I took a quick few measurements to see how much of the crossmember I will have to cut to fit the 98-02 f-body oil pan. Looks like it will be minimal!
      Needed to do something visibly productive last night so I took the ugly cast aluminum alternator/power steering bracket and ground down the casting marks and painted with theVHT crinkle paint.
    16. #56
      Feb 2006
      Enumclaw, WA
      Parking brake cable was cut under car so decided to mount the 2011 clutch/master assembly there. Need to shorten pedal about 1.5"as well as adjust angle but it should get the job done for now.
    17. #57
      Feb 2006
      Enumclaw, WA
      Well a local Chevelle guy and I are going to upgrade the trunions on the stock LS rockers. Stock rockers with Comp trunions male for an excellent set of rockers. My stock rockers sure were loose! Add a big cam to them and I'm sure some of the needle bearings in that cup would be in my motor.
      Took the stock ones apart in the bedroom...fiance appreciated it. :D
    18. #58
      Feb 2006
      Enumclaw, WA
      Only took me about 35 minutes to install all 16 trunions! Think I may do a few more sets to sell.
    19. #59
      Feb 2006
      Enumclaw, WA
      Bumpstick ordered this morning...:D
      Thunder Racing seems to be having some business issues so I called Geoff @ EPS and bought a 226/234 .598/.601 113+2
      His reputation is great and the EPS lobes seem to be very popular so I'm excited to finally get that purchase out of the way.
    20. #60
      Feb 2006
      Enumclaw, WA
      Well drivers header hit due to proportioning valve. So I did some gentle massaging and all good. Also laid out the full exhaust so I...well just because us car guys do that stuff haha.
