Results 1 to 20 of 25
10-27-2011 #1
- Aug 2008
- 59
Should I align frame before welding SFCs in first gen?
I'm about to have subframe connectors welded to my 68 Camaro with an LSX. I don't know whether the frame has been in an accident, whether the front and rear frames are square with themselves and/or each other. Car seemed to drive straight and now I put in solid body mounts (one side at a time - haven't tested it at speed).
If the car runs straight at speed and aligns fine, how big of a deal is it to make sure the frame is perfectly square? I tried measuring it but I am not quite sure that my measurements are accurate. I went to a collision shop and they told me 8-12 hours of labor just to measure the frame. I promptly left. I assume welding SFCs will make the front frame impossible to move relative to the rear. Do you guys think it will be ok to just weld up the SFCs and go, or should I make sure the frame is 100% straight first?
10-27-2011 #2I would make sure it is square first. Its not that difficult to check, but it will be harder to adjust with the engine/trans installed.
10-27-2011 #3
- Jan 2010
- Elk River, MN
- 676
There should be some tricks to aligning it in your own garage/shop. I'd at least want to check it for peace of mind before welding everything up solid.
-mattMatt Peterson 84 Monte Carlo - Sold :( | 99 Corvette Racecar | 2001 Z06 Daily Driver
https://www.pro-touring.com/showthre...ng-Bertha-Back
http://ls1tech.com/forums/conversions-hybrids/1499192-84-monte-5-3-build.html
https://www.pro-touring.com/threads/...rvette-Racecar
10-27-2011 #4
