    Page 1 of 8 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 151
      Oct 2011
      Infinity Camaro LS3 Project
      Hello,
      My 1968 Camaro "project" started out im 3-2011 as a rust free (pretty
      much) restored Pro Touring car.
      It came with a 383 stroker and a 5 speed Tremec transmission.
      I really couldn't post this build on a "true" Camaro site, as I would
      most likely receive tons of hate mail. What I did to the car after I
      received it would be considered wrong on so many levels by Camaro
      purists.
      2-2011
      Purchased my "restored" 1968 Camaro coupe.
      4-2011
      Drove my new car to the performance shop
      Pulled the entire drivetrain, which was sold to another enthusiast
      4-2011
      Towed car to local body shop for a "freshen up" on the paint
      4-2011
      After doing a thorough review of my body and paint work,
      we decided to do an entire repaint, as well as a few
      other tweaks. After reading several articles, I decided to have the car painted
      with all panels, trim etc. off the car.
      Body disassembly started
      After owning 3 cars with LS drivetrains, decided to treat this car to the same.
      Started collecting information on how to swap an LS drivetrain into my car.
      After some research, started collecting parts for the project
      Year to date collected parts include:
      Katech LS3 crate motor (Forged Mahle flat top pistons, Katech rod bolts, ARP head studs, hardened pushrods, PRC dual spring kit,
      C5R timing chain, Total Seal second ring, Melling high volume oil pump, ECS "small" blower cam mid 230's, 588 lift on a 117 LSA)
      JRE Fuel System Upgrade
      Injector Dynamics ID850's
      PSI Conversions Engine wiring harness
      New Camaro LS3 throttle body
      C&R Racing LS Steam Vent Kit
      All new GM sensors
      Holley Alternator \ power steering bracket (Powdercoated satin black)
      Alan Grove Components Low Mount A\C bracket (Powdercoated satin black)
      SLP under drive crank pulley
      ARP crank pulley bolt
      Holley power steering reservoir kit
      New Sanden A/C Compressor
      New 160 amp alternator (98-02 Camaro style)
      New power steering pump (corvette style)
      New GM water pump (2010 Camaro style)
      New GM tensioner (98-02 Camaro style)
      Chris Alston Fab 9 rear end- w/ 35 spline axles and 3:50 gears chromoly w back brace
      Chris Alston Billet G link rear suspension
      Varishock front coilovers (adjustable) (installed)
      Varishock rear coilovers (adjustable)
      Ride Tech Tru Turn (full kit with spindles) (installed)
      Ride Tech Strong Arms (upper and lower control arms) (installed)
      Ride Tech billet gas cap
      Wilwood Superlite 6R 6 piston front calipers (front) 4R 4 piston rear calipers (Black with white lettering) 14012271 (front kit) 1409219 (rear kit)
      Wilwood slotted and drilled rotors
      8" dual diaphragm brake booster
      DSE brake booster bracket (reduced angle)
      Right Stuff stainless brake lines
      Wilwood braided brake lines (front \ rear caliper lines)
      2011 Camaro ECM (Tuned for car it came out of, tweaked to remove necessary codes,etc.)
      2011 Cadillac CTS-V drive by wire accelerator pedal (chose this vs GMPP pedal so pedal cover would fit) (Bracket powdercoated satin black)
      Ironworks bracket for CTS-V pedal (Powdercoated satin black)
      Kooks 1 7/8" swap headers (ceramic coated inside and out)
      Oxygen Sensors with 02 extensions
      Innovate LC-1 boost controller \ 02 sensor
      Magnaflow stainless steel 3" exhaust (Will ceramic coat inside and out once mocked up)
      4L80E transmission built by Jakes Performance
      Kilduff flat top horseshoe shifter (short handle)
      2800 Billet stall converter built by Performance Converters of Texas
      TCI EZ TCU transmission controller \ programmer
      TCI Paddle Shifter
      TCI LS Wide pattern 4L80E SFI certified flexplate
      BRP Hotrods sure fit crossmember (Powdercoated satin black)
      Dirty Dingo sliders (motor mounts) (Powdercoated satin black)
      Energy Suspension motor mounts
      Energy Suspension trans mount
      Holley LS swap oil pan
      DSE quick ratio power steering box (ceramic coated)
      DSE Mini Tubs (installed)
      DSE Radiator closeout panel (will paint body color)
      Oversize Sway bars front and rear w\ all new Energy Suspension end links, bushings (greasable)
      BMR Del Rin subframe bushings (installed)
      BMR Weld in subframe connectors (installed)
      Moog ball joint
      Moog pitman arm
      Flaming River powdercoated tilt column
      Entropy LS swap radiator with aluminum shroud and dual built in fans
      C&R Racing Camaro direct fit heat exchanger model 56-00010
      Aeromotive Phantom dual fuel pump setup (340lph E85 pumps)
      Aeromotive 13101 fuel regulator (switching out for 2 port)
      Aeromotive 12335 filter (switching out)
      Right Stuff 3\8" stainless fuel line (switching to one 5/8" supply, 1/2" return)
      Powder coated aluminum radiator overflow
      Rock Valley narrowed stainless steel fuel tank
      Anti squeak kit (neoprene) for gas tank
      Braille 3121 battery in trunk (centered behind seat)
      Braille aluminum battery mount
      Dakota Digital guages (VHX Carbon, blue backlighting)
      Dakota Digital Boost module
      Dakota Digital digital gauge control for Gen IV Vintage Air
      Painless Phantom Key push button start
      Tri note horn
      New Corbeau GTS seats II (sold Recaros in photos) Beefing up foam bolsters and springs for longevity
      Corbeau seat brackets with double locking sliders
      Passenger and driver seat bracket extensions (more leg room)
      Rear seat (Mikes Custom) Seat is custom made fiberglass with foam. Covered in Ultraleather Raven Wing with Camaro emblems
      Heated Seat kit with carbon fiber elements
      Alien Enclosures trunk enclosure (black vinyl with suede inserts)
      Rushforth Night Train 18x10 18x12 wheels in Black Chrome III
      Toyo R888 tires 275 front, 335 rear
      Flaming River tilt painted steering column
      Momo "Quark" series steering wheel
      Custom fiberglass console (covering)
      Trim Parts one piece Essex carpet
      3 point seat belts (Morris Classic Concepts)
      Rear Morris Classic Concepts Lap Belts
      Morris Classic Concepts Driving Lights
      Pioneer 7" DVD App radio (replaced JVC chameleon)
      Jl Audio HD 900 class D Amplifier (very compact, yet powerful and clean!)
      Jl Audio 10" subwoofers (10w3)
      CDT Audio Euro front component speakers
      Monster cable speaker wiring \ rca cables
      Stinger battery terminals, fuseblock
      Accel lightning 1\0 guage power cable from alternator to battery location in trunk. Very light and flexible cable.
      Accel Lightning 1\0 ground wires
      Accel lugs
      Fiberglass sleeving (conduit) over all accesible wiring (vehicle, audio etc.)
      Powder coated window trim (front and rear)
      Powder coated headlight \ grill trim
      New front grill (made from GM tooling)
      Exterior door handles (new)
      1970-81 Camaro bullet mirrors painted to match car. Mirror bodies were media blasted have new mirror glass,gaskets,hardware.
      All outside body seams (less engine compartment) welded and smoothed
      Lizard Skin CI soundproofing (firewall,floor pan,trunk,wheel wells,whole undercarriage) (installed)
      Anvil Auto Carbon Fiber Front Valance
      Anvi Auto Carbon Fiber Header Panel
      Anvil Auto Carbon Fiber Hood (waiting on another from Anvil Auto as mine's warped)
      Anvil Auto Carbon Fiber Cowl Panel
      Anvil Auto Carbon Fiber Trunk Lid
      Anvil Auto Rear Spoiler
      Billet Hood Pins (ordered from Anvil, brushed aluminum)
      Fesler Hood Hinges (natural)
      Fesler Hood latch
      Fesler Hood adjusters (stainless)
      Fesler large f door jamb vents
      Fesler billet strikers
      Fesler headlights
      Inner glove box (new)
      Carpet guard (new)
      Master screw kit (inside and out)
      Billet Specialties Pro Bolts (front inner sheet metal stainless bolts)
      Totally Stainless body bolt kit
      Metro MP 15 year weatherstripping, bumpers, grommets etc. (the best!)
      All new interior knobs
      All new glass
      All new glass hardware (mounting hardware, stops, everything)
      Eddie Motorsports taillight bezels
      Eddie Motorsports trunk hinges
      Eddie Motorsports marker light bezels
      Lokar aluminum pedal covers
      Nu Relics power window kit (front and rear)
      Vintage Air A\C (Gen IV)- SPAL fans!
      American Autowire Classic Update (wiring harness)
      Raingear Hidden Wiper Motor
      Custom order black wiper arms
      Lokar parking brake pedal and cables
      All new locks with late model GM key (coded to one key)
      Innovate LC-1 boost controller with 02 sensor
      DEI door lock actuators
      Airaid Powdercoated cold air box (will run 4" stainless single piece tube from here to motor)
      Modern Classic Interiors fiberglass dash pad
      Modern Classic Interiors full length center console
      Modern Classic Interiors center dash bezel
      Marquez Designs rear package tray
      Marquez Design trunk lid cover (May use TMI instead)
      TMI one piece fiberglass unisuede headliner (black unisuede)
      TMI unisuede door panels
      TMI unisuede rear panels
      TMI unisuede sail panels
      TMI unisuede a pillar covers
      TMI unisuede visors
      Fiberglass kick panels (Screamin Performance) covered in Ultraleather Raven Wing
      Billet dome light (Billet Specialties)
      Digitails Rear LED sequential taillight kit
      All new marker lights
      All new lenses including taillights
      LED markers,park lights, dome bulb
      Nu Relics Door (s) boots
      Billet Dash Vents (Restomod Air)
      Ring Brother Billet door sills
      Ring Brother Frame Rail charge port
      Still Need:
      Edelbrock dual ram intake
      Second Camaro throttle body (switching
      to Edelbrock dual intake)
      Second air intake setup
      Driveshaft (will have made once rear end is installed
      Driveshaft loop
      Doorjambs, dash, inner fenders, radiator support etc are being painted PPG Carbon Flash Metallic with PPG Ceramicoat scratch resistant clearcoat.
      Exterior will be vinyl wrapped satin metallic gray.
      Hoping to be completed late 2021 (lol-keeps changing)
      Attention to detail has been paid close attention to.
      I am building a true Pro Touring car that can do well on the road, be very reliable, even get decent gas mileage!
      550 rwhp goal N/A
      All systems built to handle much more
      I have many more photos I will be adding.
      Any input will be appreciated!
      Beginnings!
      "Old" 383 Stroker only dyno'd at 354rwhp
      Sorry! 383 wasn't getting the job done!
      Ready for takeoff! Only 747 with 4 wheels!
      Last restoration was 3000 miles ago
      Patchwork found under front fenders. One of the few replaced panels on the new transformation.
      Offensive panel removed. RH Tulip panel was good. Replaced lower sill panel (on right) as well. This was done on both sides of car.
      New Tulip panel installed.
      Closeup of LH lower door jamb replacement panel. Same panel replaced on other side of car.
      DSE steering box
      Solid floorpans. Had been replaced upon last restoration.
      Even left some blast media under the carpet!
      Burnaby, BC, Canada
      Nice project, looks like you have a good plan and list of parts and that's quite a nice car your starting out with.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Oct 2011
      Thanks so much!
      My father owned a '68 Camaro. Out of all the cars he owned, he loved
      it the most. I always loved the first Gens as well.
      I had a hard time getting past the feel of a new car.
      LS motors and the six speeds that go with them kinda ruined me.
      My last car was a 2007 Z06.
      I am new to the Pro Touring scene and had to do many, many, hours
      of research on my own to get where I am. I ordered all that has been done.
      Not turning any wrenches, but designing all on my own. As you know, no one
      has a complete book on everything you need to know to swap these in.
      I put together my parts list in an effort to help others in their design.
      You car is awesome! Love the '69 body. Didn't see as many high end 68's,
      so this one has to be exceptional! I am cutting no corners and am taking the time
      to get the parts and the look I envisioned. Their are some undivulged design plans for the
      car that will be shown once finished. This will be a one off design that will keep the classic
      look, but nothing else. I hope others will like my taste, as I see many customs that are loved
      solely by the owner. LOL.
      Regards
      looks good! very nice project and good work so far! already looked great before in silver! but it'll be also nice painted black. can't wait to see more of the progress!
      Oct 2011
      Thank you!
      I have owned both colors, liked the black better when it was clean.
      My reservation with black was that it spiderwebs easily.
      The spiderweb effect is supposedly non existent with the PPG Ceramiclear that
      I am using. Otherwise, I would have stayed with silver. I do have two other silver vehicles,
      thinking three may be a crowd.
      Going to include pics of the minitub job as it will be done tomorrow.
      Thinking of pulling the frame and powdercoating it, as car is pretty much a roller.
      Especially since we notched and boxed the frame. No rust for me! Guess it's my OCD acting up!
      Have to know that car has absolutely zero issues.
      Thanks for the comments.
      I am thinking of using a Ford 9" for the rear end, but am looking for recomendations.
      Also need help with the fuel system, as car should be over 600rwhp. Aeromotive has a new intank pump
      that fits in place of a Walbro that should support this kind of power.
      Don't know what to do on the rest, as I am not sure the Corvette regulator will work. Thinking hardline, or Teflon (Aeroquip brand) fuel lines,
      maybe a combination of both. Thinking Rick's tank.
      Looking at Speed Tech Performances torque arm setup, as I will be running 345's vs 335's in the rear. May do their coilovers in front as well.
      Also need help with a custom intake. Thinking of custom bent stainless pipe (maybe powdercoated black). I want the least amount of joints possible.
      Looking at a custom rear seat, as I am unsure of mine, with the minitub. Maybe a Mike's Custom setup?
      Door panels. Looking at Fesler and Marquez.
      Any recommendations will be greatly appreciated!
      Everyone here has been so cool!
      Aug 2011
      Wow, and what was wrong with what you started with? lol
      That far exceeds anything I would have been happy to start with!
      Hey, if you've got the means, go for it!!
      Cool car!
      Project High School Sweetheart
      65 Chevelle 300 2dr Sedan = "CURSD65"
      Oct 2011
      Well, hate to say it.....but
      The car felt old...lol
      Aug 2011
      They're never really finished anyway... lol
      Oct 2011
      Thats what I was saying! Really wanted a good base to start from. Felt I bought just that.
      Jul 2011
      Looks great!where u get center console at??
      Oct 2011
      Quote Originally Posted by Bmf5150 View Post
      Here ya go!!!
      www.modernclassicsinteriors.com
      My design is sorta like the Machete
      It will be posted to the site soon, as I am receiving the first one designed
      specifically for the '68 Camaro.
      Oct 2011
      Just had mini tub kit installed.
      Back at body shop getting soundproofing done,then back to paint booth.
      More photos soon. Car is taking a while, but will be great when finished.
      Orangevale, Ca
      This should be a good one, keep us updated with pics and good luck with your build...
      Jan 2011
      Boston, MA
      Car looks great, I'll be following this one for sure. Don't worry about what people say on other sites, there will always be purists. It's your car, do what you want with it. I started with a Plain Jane '67 because I didn't want to hack up a real SS or Z, but didn't want to be stuck driving and "old car" either. Still a work in progress...
      Oct 2011
      Heres my new center console. It is very well made and one of the coolest parts of the interior. My particular console was the first one built specifically for the '68 Camaro and is the one pictured on the website. modernclassicsinteriors.com MCI is now a forum vendor!
      It will be covered in black leather. The lid opens to a large compartment. The inside bottom of the compartment is lined with neoprene.
      Oct 2011
      A website called modernclassicinteriors.com doesn't exist. Can you please recheck the website? Thanks!
      Orangevale, Ca
      Oct 2011
      Got it thanks
      Oct 2011
      Katech forged piston LS3
      Dakota gauges
      Taillight bezels
      Trunk hinges
      Side markers
      Corbeau seats (will be covered in leather to match rear seat, no headrests when done)
      Bullet mirrors will be painted body color
      335MM Toyo R888
      Gas lid
      Mini tub is done
      Seam sealing tubs, floor pans, cowls etc.
      Oct 2010
      Longwood, FL
      Gonna be one sick ride! Kudos to doing what you want with the car and not caring what people think! I'm also on a chevelle site and there are plenty of people not pleased with my concept! Lol... Surprisingly, there are actually alot that do though. Looking forward to sreing your surprises. I love outside the box!
      Zip
      project 72 chevelle rs1
      Used to be known as streetmetal
