Thread: Baffled - Brake Booster issue?
10-16-2011 #1
New to Pro-Touring
- Nov 2005
- 5
I recently had my 69 camaro out for an evening cruise and while driving noticed the pedal travel was becoming increasingly spongy. Figured I might have a caliper or cylinder leak but after pulling the wheels (disc/drum) there are no leaks. The car does brake but braking is poor and the pedal travel is to the floor. The car has all new OEM brake calipers, wheel cylinders, lines and has been functioning properly for a year. Brake fluid in the master cylinder is fine as well. I jacked the wheels off the ground (back and front) and a buddy of mine spun the wheels while the car was running and applied the brakes and the wheels stop immediately. With no leaks and the brakes applying to all four wheels I am thinking this is a brake booster issue? How can I confirm this is the case? Could I have a master cylinder issue?
Thank you,
Ken
