    Results 1 to 20 of 32
      Jun 2019
      San Jose CA
      1970 Hellcat Challenger Build!!!
      Hey all, starting on my 70 Challenger hellcat swap. I picked up the car 5 months ago and started ordering parts immediately. Only rust was the trunk pan and I'm replacing that now. I'm also going to minitub at the same time. Once I get that finished I'll start taking the original motor/trans out.
      Build will consist of the following:
      RMS Alterktion front coilover suspension +1" Forward with ridetech shocks
      RMS rear street lynks 4 link with a ford 9"
      Willwood brakes all around
      New 2018 Hellcat Redeye long Block
      2.4 supercharger ported supercharger by Jokerz performance
      E85
      Holley center sump oil pan
      Holley Trans Crossmember & mount
      Factory Auto 8hp90 transmission
      Dakota Digital Gauges
      I'll be sure to log and update the build as it progresses. I'm doing everything myself when time permits.
      Let me know what you guys thinkName:  IMG_8895.jpg
      Jun 2019
      San Jose CA
      Jan 2024
      Gainesville, Ga
      Awesome! Love the color, looking forward to watching this one
      What a great car to start this project on!
      Apr 2018
      Totally cool color! Subbed to follow your progress
      Oct 2015
      Beautiful car. Looking forward to the build.
      Jun 2019
      San Jose CA
      I got the US Cartool frame notch just about finished on the driver's side. I need to weld in a strip of metal for the minitub. I hope to start on the pass side this weekend. Slowly Making progress.
      ATTACH=CONFIG]212077[/ATTACH]Name:  20240208_174031.jpg
Size:  405.9 KBName:  20240208_174001.jpg
Size:  400.0 KBName:  20240208_172134.jpg
Size:  446.3 KBName:  20240208_173955.jpg
Size:  425.0 KBName:  20240208_174035.jpg
Size:  488.9 KBName:  20240208_174031.jpg
      This should be really cool!
      What are the current plans for engine and transmission management? I am currently working on Holley EFI and TurboLamik 8HP TCU integration.
      Jun 2019
      San Jose CA
      Standalone engine and trans harness from Chris @ hotwire auto. He's not cheap but probably the most knowledgeable on the hemi platform. I'll be utilizing the stock pwm fuel set up with a tank from ricks. I have a tapped performance dual pump set up from my charger hellcat. In the end the fuel system will be like a factory hellcat.
      How is the Holley stuff? I looked into it briefly but it didn't seem they had much for the hellcat when I looked back then.
      - - - Updated - - -
      Standalone engine and trans harness from Chris @ hotwire auto. He's not cheap but probably the most knowledgeable on the hemi platform. I'll be utilizing the stock PWM fuel set up with a tank from ricks. I have a tapped performance dual pump set up from my charger hellcat. In the end the fuel system will be like a factory hellcat.
      Quote Originally Posted by 1moretoy View Post
      The Holley EFI works great, but there is no HellCat specific harness that is available.
      Jun 2019
      San Jose CA
      Pretty much have the pan fitted for the last time. I got all the holes drilled for the spot welds finished this evening. Weld through primer is in the right places as well. I should have the pan finished up this weekend. After that I'll complete the mini tubs then onto the suspension 😁
      Jun 2019
      San Jose CA
      I got the driver's side minitub welded in. Just need to grind down all of the plug welds & seam seal. I'll stich weld the inside and use seam sealer as well.
      One step closer to starting on the suspension.
Size:  197.9 KBName:  20240304_210250.jpg
      Sep 2013
      sw Kansas
      Different skill levels, different speed levels. If you only have to do it once, you did all right. Have you got to talk to users of the ecu package you mentioned to see how well it has performed?
      Jun 2017
      This is going to be awesome. My 12-year-old son wants to build the exact same challenger/hellcat combo. I'll be watching this closely.
      Jun 2019
      San Jose CA
      Finished up the mini tubs and trunk pan. I'm working on the subframe connectors now. I have posted some videos on YouTube as well. I also made some casters so I can remove the rear end and still roll the car around.
      https://youtube.com/@HellcatKev?si=ECjeS8lv8hxHOn2w.
Size:  431.8 KBName:  20240407_191516.jpg
      Jun 2019
      San Jose CA
      Received my tank from Rick's, and oh boy is this thing sweet. Almost too nice to hide under the car.
      I'm working on the subframe connectors and should have them done today.
      https://youtube.com/@HellcatKev?si=0PCZIKhZ93x8a-7W
      Jun 2019
      San Jose CA
      I was able to get the subframe connectors finished and the RMS streetlynx mocked up this last week. I'll finish welding the 4 link in this week and then start on pulling the motor & trans.
      1970 Sublime Challenger Hellcat Redeye swap
      Jun 2019
      San Jose CA
      Hey all, Working on the cooling now. I'm mocking up the radiator, heat exchanger and AC condenser. I'm going to push the radiator back 2"or so using some angle iron. This should allow enough room for the heat exchanger and condenser. I still need to cut the sides of the core support for the larger 26" core. So far so good, hopefully my plan works. The cardboard is my template to space the radiator back. Anyone see an issue doing so? I plan to block the sides and top to keep the air flow directed to the radiator
      What fans are you going to use? Hopefully something that moves a lot of air.
      For sure! That radiator should get moved forward so there is more room for the fan. The fan in HellCat cars is actually very similar to the 6th Gen Camaro 850 watt fan. Presumably the ECU of choice is able to output the pwm signal to run a powerful brushless fan.
