Results 1 to 20 of 23
Thread: Art Morrison rear clips
Hello to all,
I usually do more reading and learning from you guys than asking but I'm at a cross roads with my 69 Camaro.
I have talked with Don at A.M. about their new Max G chassis. I think it will be a great product but for my intended use, I think it will be drastic over kill.
My situation is this, I have a new one piece floor, trunk and rockers all tacked in place in the car. I have zero confidence in the rear frame rails staying straight and holding up due to rust. I will mini tub this car so part of the frame rails will go away any way. I'm looking for opinions on installing one of A.M. rear clips, be it a ladder bar set up, 4 bar or triangulated 4 bar. I would like to maintain as much of the factory floor look as possible....no pro street, tubbed out look.
I was ready to order DSE's rear kit but after looking at the A.M. stuff, I think this would solve most of my concerns.
My intended use will be strictly street use, there are no road race courses around central Florida, so handling will be important but not to the extent as most of you look for. My front end set up will consist of tubular arms and possibly a coil over conversion with all the usuall other upgrades.
Thanks for any input.
Tim
06-28-2005 #2
- Feb 2005
- 320
I too am looking to go this route although I plan on putting the entire Max G chassis under my 68 camaro. I would also like opinions from the experts on this board as to what to expect from this chassis over stock unibody. I will be ordering it with A.M.'s front suspension rather than the C5 front suspension. Any feedback would be greatly appreciated. Thanks Chris
06-28-2005 #3Tim- I might be a little biased, but our trianglulated 4-bar works great for the application you want. Art's 55 has this suspension under it. He has pounded the car for 4000 miles and it works great!
Our IFS works very well. Again, its the suspension that we have on our GTSport chassis that is under the Tri5's. I just started building a 53 Stude for my wife and it will have our IFS up front and tri 4-bar in the rear.
Hope this helps. If either of you are ever up in the Pacific NW stop by the shop and go for a test ride in the 55 to see how this suspension feels.
06-28-2005 #4
- Sep 2004
- 58
We may be starting a Max G chassis for a 1968 Camaro very soon. Waiting to work out the details with the customer now.
Daryn
06-28-2005 #5We are just finishing up a 68 Max G IFS / tri 4-bar chassis right now! I'll take some pics for you. If you need anything else, please call & fire away!
06-28-2005 #6
- Sep 2004
- 58
Craig
Look forward to the pics. i sent you an email with a couple questions. We will be in touch soon.
Daryn
06-28-2005 #7
New to Pro-Touring
- Sep 2004
- 75
Just my .02
I installed an AM 4-bar setup with QA1 coilovers in my 69 camaro. I am very happy with the results. I've put about 1000 miles on the car already (driving to and from the Pigeon Forge event) I still need to dial things in before autocrossing, I will go a little stiffer on my rear springs, but I am impressed with the results so far.
07-05-2005 #8
- Feb 2005
- 320
Craig,
Is it possible to have engine mounts for a big block chevy and transmission mount for a turbo 400 installed from the factory or is this a definite do it at home type thing? The frame I order will have your suspension rather than the C5if this helps dimension wise. I will be placing an order for one of these frames in the beginning of August. Thanks Chris
07-05-2005 #9
- Jun 2005
- 29
Looking at one of these possibly for my 68' camaro. I looked on the site but couldent find any info on prices, dose anyone know about how much one of these would cost? Thanks
07-05-2005 #10
- Jun 2005
- 29
nvm I found the prices in a similar forum on lateral-g.net sounds like a great price for what you get.
"The price for one of these chassis with tri-4 bar rear and C5 front is $12473. That is a fully welded chassis with sway bars, shocks (single adj Strange), springs, RE housing, Strange 3rd member with your gear choice & posi unit, 31 spline Strange axles, power rack (20:1 or 15:1 ratios), all the C5 components direct from Chevrolet (not used pieces), Corvette C5 brakes up front & Wilwood brakes in the rear.
With C5 front suspension, you will be limited to Vette backspacing on the wheels and will need to move the motor back about 5" to clear R&P, which aren't really bad things since you will have a very small scrub radius and killer weight balance
The price for this chassis with tri-4 bar and our IFS up front is $1056.00 that includes all of the above but with our IFS up front and brakes are our 11" disc kit in front and the SVO disc kit in the rear. Other brake upgrades are available. With the IFS you don't have the dramatic engine setback due to its rack location and have a larger variety of wheels to choose from."
07-06-2005 #11Kevin- there is one typo in there. It is $10056.00. We do have a few different options, air, IFS, C5 front or air, 4-bar, tri 4-bar rear. Rear-end is narrowed to your tire/wheel package.
Sorry gotta catch a plane to Columbus, if you have any other questions, please let me know!
