Results 1 to 20 of 23
Thread: Art Morrison rear clips
06-28-2005 #1
Hello to all,
I usually do more reading and learning from you guys than asking but I'm at a cross roads with my 69 Camaro.
I have talked with Don at A.M. about their new Max G chassis. I think it will be a great product but for my intended use, I think it will be drastic over kill.
My situation is this, I have a new one piece floor, trunk and rockers all tacked in place in the car. I have zero confidence in the rear frame rails staying straight and holding up due to rust. I will mini tub this car so part of the frame rails will go away any way. I'm looking for opinions on installing one of A.M. rear clips, be it a ladder bar set up, 4 bar or triangulated 4 bar. I would like to maintain as much of the factory floor look as possible....no pro street, tubbed out look.
I was ready to order DSE's rear kit but after looking at the A.M. stuff, I think this would solve most of my concerns.
My intended use will be strictly street use, there are no road race courses around central Florida, so handling will be important but not to the extent as most of you look for. My front end set up will consist of tubular arms and possibly a coil over conversion with all the usuall other upgrades.
Thanks for any input.
Tim
06-28-2005 #2
- Feb 2005
- 320
I too am looking to go this route although I plan on putting the entire Max G chassis under my 68 camaro. I would also like opinions from the experts on this board as to what to expect from this chassis over stock unibody. I will be ordering it with A.M.'s front suspension rather than the C5 front suspension. Any feedback would be greatly appreciated. Thanks Chris
06-28-2005 #3Tim- I might be a little biased, but our trianglulated 4-bar works great for the application you want. Art's 55 has this suspension under it. He has pounded the car for 4000 miles and it works great!
Our IFS works very well. Again, its the suspension that we have on our GTSport chassis that is under the Tri5's. I just started building a 53 Stude for my wife and it will have our IFS up front and tri 4-bar in the rear.
Hope this helps. If either of you are ever up in the Pacific NW stop by the shop and go for a test ride in the 55 to see how this suspension feels.
06-28-2005 #4
- Sep 2004
- 58
We may be starting a Max G chassis for a 1968 Camaro very soon. Waiting to work out the details with the customer now.
Daryn
06-28-2005 #5We are just finishing up a 68 Max G IFS / tri 4-bar chassis right now! I'll take some pics for you. If you need anything else, please call & fire away!
06-28-2005 #6
- Sep 2004
- 58
Craig
Look forward to the pics. i sent you an email with a couple questions. We will be in touch soon.
Daryn
06-28-2005 #7
New to Pro-Touring
- Sep 2004
- 75
Just my .02
I installed an AM 4-bar setup with QA1 coilovers in my 69 camaro. I am very happy with the results. I've put about 1000 miles on the car already (driving to and from the Pigeon Forge event) I still need to dial things in before autocrossing, I will go a little stiffer on my rear springs, but I am impressed with the results so far.
06-28-2005 #8Hey! Thank you :icon996:
06-28-2005 #969...how did the setup tie into the stock trunk and floor pans? Were you able to create the mini tub effect?
Thanks for the reply's!
06-29-2005 #10
- Oct 2004
- NJ
- 769
