    Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 21 to 40 of 123
    1. #21
      Jul 2008
      Ft. Worth, TX
      Well I'm still figuring out the rear spring issue and the ac compressor brackets aren't going to work the way I wanted. I am using edelbrock motor plates and the compressor is all over the motor plate and mount. So back to square one!
    2. #22
      Aug 2011
      I am doing the LS3 71 Chevelle. I am using the Kwik brackets for a Sanden compressor its slick you should check it out. Its affordable too. Google Kwik brackets. I actually bought the brackets for the alternator and power steering from a bone yard for 150 bucks minus power steering pump and alternator. I plan to get the Kwik/Sanden setup to finish the accessory drive hopefully with a total of $500 for the whole front accessory drive system.
      I got an LS3 crate engine and am doing a cam only with Stainless Works headers and 3" exhaust. I found the headers and exhaust discounted on Byun Speed. I paid around $1800 for the 1-7/8" headers and 3" exhaust system (retail would be about $2100). Folks on the LS1 tech forum are getting 460 RWHP with the cam and long tubes (2010 Camaro's) so it should be fun. I really wanted the LSX like you have but couldn't budget the money for it. It would have costs me easily 5K more than what I have in my LS3.
      How in the heck do you get to try out so many wheels. That's not fair. I am really struggling with wheel choices. The wheels I like all cost 2.5K plus which is crazy. I really like the Fikse profile 5 in bushed/clear best I think. You can check out my build on here too 1971 Chevelle SS clone LS3 swap. Love your car :-) going to watch yours too.
      I love the late model GTO seats too. Nice choice. I went with an 04 Z06 pair of seats. I was able to get the power seat to work fairly easily too.
      I'd rather have the GTO seats but hard to find at a reasonable price. I got a good deal on the Z06 seats and they look nice just the Z06 logo is kind of odd.
    3. #23
      Apr 2010
      Chandler, AZ
      Nice Build!!
      70 Chevelle LS3 T-56 Whiplash Rushforth Wheels.
      Paint design by Jason Rushforth
    4. #24
      Jul 2008
      Ft. Worth, TX
      I have seen the kwik a/c bracket but I wanted to keep it low mount so I could run the ac lines under the fender for a cleaner appearance. Now I may just break down and buy a kwik bracket. There is also a one piece billet bracket on eBay. Looks simple to make on a mill. So that's up in the air right now. Finally got the motor set where it needs to go. The passenger hear is 1.75 inches from the firewall and I have an inch of clearance between the f body oil pan and the crossmember.
      I got all of my front accessory brackets from a local gm dealer for about 200 bucks. I got my water pump from a local guy off a crate ls3. I still need an alternator and power steering pump.
      I own the black z06 wheels and a buddy had the c5 speedlines. I liked the c5s but the fronts were too narrow (only 8 inches wide). The z06s are 9.5 and 10.5 wide. I have to run spacers with the corvette wheels but they are full billet with hardened studs so I don't think they will be an issue. I torque everything religiously anyways. I am looking at the new zr1 replicas. It is hard finding 18x10, 18x11,19x11 cast style (affordable) wheels. They do make the zr1s in 19x12 but that's a little too big unfortunately. I wish some 2 or 3 piece wheels were in the budget but there arent. I like The whole Fikse line up but the profil 10 is my favorite.
      I ended up cutting the top pig tails off of my drop springs (1.5 inches total) for a total of 2 inches of drop. I need to check rearend to floor clearance since I am running a moser m9 which is massive. I also need to check shock clearance and stroke length. Now I need to cut the spring adjusters in the front to drop the front some more.
    5. #25
      Aug 2011
      Nice. What are you going to be using for engine management with that intake setup?
    6. #26
      Jul 2008
      Ft. Worth, TX
      I am building a stand alone harness and I will be using a 2002 f body ECM. I will place the air intake temp sensor in the air filter base and run it in speed density mode. I will also be using a wide band for tuning. I had a 94 camaro a while back that I swapped an ls1 into. It always ran better with a speed density tune than a Maf tune.
    7. #27
      Aug 2011
      I did the same with the brackets got them for 300 with tensioner and a power steering pump reservoir and a PS pulley all for a Vette setup. I too need the alternator and PS pump. The alternator and PS pump are not cheap. Found some used ones 90 for alternator and 125 for pump.
      I am kind of up in the air about what kind of suspension to go with. You know the LS3 is about 100lbs-150lbs lighter than what I had. Plus I am putting battery in the trunk and putting a cold air intake box where the battery was so thats pushing about 200lbs off the front. So ride heights and springs/rates going to be tricky. I thought about using the adjustable lower control arms in the SC&C kit http://scandc.com/new/node/740 so I can tweak the front if need be.
      BTW what kind of fuel tank setup you gonna go with?
    8. #28
      Jul 2008
      Ft. Worth, TX
      I am just going to keep an eye out on e(vil)bay for the alternator and ps pump. I have a buddy that runs an autoparts store and can get me a good discount but it is still some cash.
      The LS3 set up is much lighter than my all iron bbc i had in there before. I am adding a few things back in, such as a/c, ps, radio, heat, power seats and a few other things. I still think the car will be about the same weight after I am done. Im not sure if I want to keep the battery in the back or put it back in the front for a factory look. I may keep it in the back because I want to autocross the car some and the factory hold down is pretty flimsy. I've already had one battery take a dive into the alternator so Ill probly just keep it where it is. Also it will make the audio wiring easier if I keep it in the back.
      Well I haven't locked down the fuel system yet but I do have a nice factory tank that I may cut open and baffle. Then I would just integrate a walbro pump onto the stock pick up. I also have a 96 b-body tank that I may throw in there. I don't like how much they hang down but the extra capacity will help with the trip on power tour. Also I wont have any issues with the pump sucking air with the impala tank.
    9. #29
      Sep 2011
      Las Vegas,nevada
      I like the draglites the best on that car.
      I live my life a quarter mile at a time cause for those 10 seconds I don't have a care in the world.
    10. #30
      Quote Originally Posted by Mikes83ss View Post
      He had to swap them because the 80's called and they want their wheels back...
    11. #31
      Apr 2010
      Chandler, AZ
      LOL!!! They are the best looking drag wheels but for sure they belong in the 80's or just drag racing.
    12. #32
      Jul 2008
      Ft. Worth, TX
      That is funny. To be fair, I do like draglites but they only do one thing well, go in a straight line. Now Andrew, the eighties didn't call to get the wheels back, a guy with an 80s mustang called and got them. Thats what they are on now. Andrew, nice goat by the way.
    13. #33
      Jul 2008
      Ft. Worth, TX
      Well a buddy of mine is setting me up with a great deal on a new set of z06 c6 brakes and new rear intro pentias in 20x10 with new tires. A deal I can't pass up. So I have a c5 z06 front and 12 inch rear ford explorer disc set up for sale. Thanks ole blue.
    14. #34
      Apr 2010
      Chandler, AZ
      Great setup!
    15. #35
      Jul 2008
      Ft. Worth, TX
      I didn't want to change up the set up this far along in the build but it was a deal I couldn't refuse. Now if I can sell my old set up.
    16. #36
      Jul 2008
      Ft. Worth, TX
      Well here are a few pics of the new wheels in mock up. I need to narrow the m9 housing a few inches to get the wheels to work.
    17. #37
      Jul 2008
      Ft. Worth, TX
      Forgot to add, the rear is at ride height and the front needs to go down a few inches. I am going to wait to set that until I get my front wheels and tires. The tire size on the rear is 295/40/20. A little taller than I wanted to run but they are brand new bfgs and came with the wheels, so I will use them for now. Next time I will run a 295/35/20.
    18. #38
      Jul 2010
      [QUOTE=Chevelle598bb;824744]
      Were did you bolt the harness without a roll bar?
    19. #39
      Jul 2008
      Ft. Worth, TX
      The lap belts were bolt to the stock seat belt locations. The top harness was just put through the seat. Those pics were before a cage was installed.
    20. #40
      Apr 2010
      Chandler, AZ
      Looking great!
