      Jul 2011
      Owensboro KY
      What would you do?
      Looking forward to the start of my LS build and would like to get some suggestions on what works for other people. Heres what Im starting with:
      I have a 2005 LQ4 Block with 317 Heads..
      Pretty bland I know, but I plan on replacing everything but those two. I was given the long block by a guy who took it out of a Tige Ski Boat that somehow managed to try and compress a little bit of water. This broke the piston, one valve, bent the connecting rod (and Im assuming make the crankshaft unuseable) To the best of my knowledge, the block and head are salvageable although this has yet to be confirmed by the machine shop.
      So heres my question, given the block and heads that I have, what would YOU do? Keep in mind that this will be strickly a street car (71 Camaro) so it will run on pump gas. Im all for a turbo (I was given the factory truck manifolds that came on his replacement motor), Im not scared of nitrous if its a small shot and Im totally for a stroker since my stock rotating assembly is possibly shot.
      If you were in my situation, how would you approach the build?
      Thanks ahead for any suggestions, if something similar has worked for you dont be scared to throw it on here.
      May 2011
      socal
      just build a 408 stroker with that motor or a 370
      hpjunky danny
      1969 camaro project wayne due c4 subframe
      2004 scsb silverado jgpclone forged 370 lq9 tt gt3071 built 4l60e trans 4:10 gears daly driver
      Jul 2011
      Owensboro KY
      So far Im sold on going with a 408. Ive been looking into the Scat 4340 cranks and Im pretty sure I will head in that direction. I pretty much plan on sticking with my 317 heads, running a lower compression and putting together a truck manifold kit so that I can run a turbo. I still have alot of shopping around to do, just wanted to get some advice from others who may have done the same thing. It seems like alot of people run LS3 heads on their engines..not really sure if Im wanting to change to those since I already have the 317s..any advice?
