Results 1 to 20 of 36
Thread: Wont run, please help
07-05-2005 #1You completely replaced all the gas as mentioned above right? If it had rust in it then more than likely it had WATER in the tank too. If you replaced all the gas then see the next couple suggestions.
Originally Posted by 1Bad68camaro
This new problem sounds almost like lack of vacuum or bad fuel pump. Is the pump new or old? Another problem sounds like choke sticking closed. Just a couple ideas for you to check. When you rev it does it return quickly or does it idle kind of high after you hit the gas then slowly idle down then eventually die?
Pictures always help a lot too if you could take a couple of those.
