Results 41 to 59 of 59
Thread: Busted and I gotta fix it
07-14-2011 #41
Life is getting busy again but I did manage time to work on mounting the Canton pickup to the Butler Pro-Series oil pump I bought. No big deal here. I did countersink the tab on the pickup with a 1/2 inch bit to make the base plate screw fit flush. Other than that it fit as advertised.
With luck I'll be washing the block this weekend and can start putting it together.
Ty, the block I picked up had already been machined for a stock 400 rebuild. Whomever did the machine work knew Pontiac blocks. They had already de-burred the lifter valley. On my last block I polished the walls to speed oil drain back. I decided not to do that this time. I don't think it makes that big a difference. I also elected to not go with street fill of hard block. I did that on my old block and it worked but the oil temps always ran high. Since this is not a race motor (most days) and more of a street cruiser and occasional weekend warrior I'm going to try running without it. I may regret it later but this is how we learn.
I did spend time last night inspecting every oil passage that can be visually confirmed. All of that looked good. Some have complained about the feed hole from the pump having flash blocking it but this one was very clean and as cast. Both galley looked true and clean but a good washing will get the previous build's assembly lube out of there for me to confirm it. I also did a visual inspect on every hole and checked the threads. It looks like the previous shop had chased them all because I didn't find a one that I couldn't screw the hardware into as needed. I'll be using studs for the mains and heads so that is important. We want our torque values to be spot on.
I did not have the block decked because I need to mock it up first and see how far in the hole we have the pistons. To do that I had to have it honed out to fit the pistons. That's next on the list as far as the block is concerned.
