    Results 21 to 40 of 59
      Little Rock, Arkansas
      Busted and I gotta fix it
      The car: 1974 Trans Am:
      This all started several weeks back. I had been to a car show. My sister had invited me over for dinner that night so I planned to drive from the show to her home. I made it most of the way before the car quit running. I was cruising along at about 50mph when it was like someone flipped a switch.
      My brother in law, Bryan Blocker of Blocker's Performance and Restoration, came over with some tools and we began to diagnose. We discovered we had no fire to the plugs and when I yanked the distributor we found that three teeth were gone from the BOP composite gear I run with my hydraulic roller cam.
      We towed it back to his shop. The building was full with customer's cars and I told him to put it on the back lot, I'd throw my cover over it, no problem. We went ahead and pulled the intake and valley pan to see if anything obvious poked its head up but it didn't. We simply laid the valley pan and intake back on top of the motor, threw the cover on and walked away. I was headed out on vacation the next week so I figured it would set until I got home.
      Unfortunately I got home and then the tornado hit Vilonia, Arkansas. That's where Bryan has his shop. He called me that night to say the cover had blown off but the car hadn't suffered any damage he could see. Considering I had family in the path of a killer tornado (4 died that night) I didn't give a darn about the car. So we spent the next 2 weeks cleaning up storm damage.
      I decided to put a new gear on the cam, hoping it was a simple gear failure since nothing else was apparent, and see if I could start it long enough to put it on a trailer. I started by draining the oil from the block through a cloth to see if I caught anything. 2 gallons of rain water later we got to the oil. Nothing there. I then poured a fresh 5 quarts of oil through the block to see if I could chase the water out. Then I topped it off, put in new gaskets, buttoned it up and gave it a shot. It fired right up and ran about 4 seconds and died. I pulled the distributor. This time it broke the gear in half.
      So the roll back was called and the dropped it at my house. The motor had to come out.
      I did that today.
      I started tearing it down. One think I was curious to see was how the Keen-sert I put in the block that time had held up. It did well. It's in the lower, center part of the picture. for those who don't know, I tried to re-torque a head bolt prior to NFME back in 2008. The threads stripped out of the block. I made a jig using an old head, drilled it and installed the Keen-sert while the block was in the car. It's still going strong! The other thing you'll see is carbon build up on the pistons. The driver's side head needs new valve guides.
      Removing the lifters I spotted this. The #1 lifter had a spot that was galled on one side.
      And it matched a spot on the cam lobe. It's hard to see in this picture but it's there.
      So all of this to say this thread will be about the tear down, diagnosis on why it did this and the build of a new engine. That engine will probably be a 461ci based on a 400 block and using a stroker kit. Watch for updates.
