      Oct 2006
      So Cal San Dimas Ca.
      afco center link
      Any body got the skinny on these?
      http://www.speedwaymotors.com/AFCO-M...ink,48370.html
      Jan 2010
      Elk River, MN
      They're on the right track, but I really like Savitske's solution better, by using all standard steering components and just going with taller lower ball joints to fix the bumpsteer issue with these cars he lowers the car 1/2" which allows better A-arm to frame clearance at lower ride heights. I've got my Monte at 5" ride height and everything is beautiful with his Stage II Plus kit.
      -matt
      Aug 2010
      now In Dandridge, Tn.
      I have used these in the past, on IMCA modifieds, and street cars. definately an improvement over stock geometry. Search out some software from Autoware, called suspension geometry pro. It is easy to use and helps you to understand the changes needed to suit your car.
