    Results 1 to 12 of 12
      Phoenix,Arizona
      LSx front pulley system??
      Hey guys, iam about to purchase a front drive pulley system for the 5.3l LSx engine i put in my dads 80 Camaro. We have looked around a little and see alot of people using the Vintage Air Front Runner kit. What are you guys using and what do you think is the best bang for the buck?
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Pensacola, FL
      I've seen the 5.3 w/truck accessories fit in the 68-72 nova. Its tight, and which hood you have may be a factor. If you want to notch the cross member you can even mount the compressor in stock location. Otherwise, I think the best bang for the buck has to be the GMPP setup. Last I checked it was around $800 with AC, less without. Check out Pace Performance site.
      Scott
      Aug 2003
      If your looking for a great set up that includes all the accessories, brackets, out 2 favorite are Vintage Air Front Runner and Wegner, Both look great and are truly built for performance and not just bling. the Wegner has the best belt wrap in the industry which is really important especially when it comes to the power steering. Because we put such big tires on the front of the cars, the power steering (power steering belt) is under a lot of pressure to turn the big meats. Many systems that do not have much belt wrap will "bark" the belt in parking lots.
      I still need to load the vintage Air Front Runners on the store, here is a link to the Wegner
      http://www.protouringsuperstore.com/...ctCode=WAWA028
      Carson city NV
      Hey Frank Will the wegner system work on a 1964 chevelle with an LS3 ? I see the power steering is a low mount will it fit the frame.
      I will need a system in a few weeks
      thanks
      Scott C
      Dec 2007
      British Columbia, Canada
      Hey Frank..I was going to ask you this eventually anyways, so why not here. Does the Wegner kit come with a water pump? I noticed it has everything else listed but that. If not, how much to add one?
      Aug 2003
      No worries, I have a high mount mounting for front steer cars. However, you might want to try it in the low position. We run it in the low position in 68-72s for sure
      Aug 2003
      Water pump is couple hundred bucks, you can get it from GM or we can supply it.
      Miami
      Apr 2007
      Surprise, Az
      I just ordered the GM kit that came with everything needed..I did it because it was what I could afford. I think the other ones listed above are much nicer.
      1970 NOVA..Ls2/Tko..Speedtech/Chicayne, Alston Glink
      Chuck D.
      Dec 2009
      Brian--
      For what it's worth, our LS Victory system will work great for your engine as long as you're not running an HEI distributor. As long as you are running the Stock style coil packs it will work great.
      Let me know if you have any other questions.
      Kevin
      Concept One Pulleys
      Made in the USA
      Dec 2010
      St Louis
      In the "bang for the buck" catagory, the GM kit is nice. But relocating the AC compressor is often required. On my 5.3, I went with the truck alt/PS pump (free) and a Kwik performance high AC bracket ($100 when bought with Classic Air kit).
      Not nearly as pretty as the ones above, but seems to work fine.
      Feb 2007
      USA, TN
      I went the Corvette accessory kit and Kwik AC bracket with SD508 compressor. Total investment is $1200 and you'll have a new AC compressor and belt you can sell on ebay to make the actual investment a little lower.
