    Results 1 to 13 of 13
      Nov 2009
      the dirty mitten
      Super car exhaust note
      I really want my car to be super high performance in every way so I want it to sound like that too. I can respect and appreciate the ground pounding loud big displacement, stroked muscle cars but that is not what I want from my car. I would really prefer an exhaust note that is similar to a ferrari or a lambo. I know that they get that from a really short stroke and high rpm but I want to get close to that if possible. Are there any mufflers that I should be leaning towards?
      The plans for my car are a 5.7 Hemi, probably a 09+ with the eagle heads, a decent cam and ECM tune. That setup is good for about 420rwhp. Im going to have AWD on the car so this will have to go into a single exhaust pipe on the drivers side, maybe oval tube for more flow? Id also like to run cats. I think they are good to about 6000rpm, I wouldn't mind de-stroking it and changing the valve springs to get to shift at 7-8k tho but I do not think anyone makes a crank for that
      Steve
      Mountain View, CA
      180deg headers
      True T.
      My blog
      Aug 2006
      San Francisco, CA
      +1, that will get the exhaust to sound about as close as you can to the italian engines.
      Good article:
      http://www.burnsstainless.com/bundleofsnakes-2.aspx
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Long Beach, Ca
      Or, If you have the room for it, an 8-1 collector. Couple of the unlimited offroad guys are running them, sound nasty!
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Oct 2010
      SLC
      some of that sound you are after comes from additional cylinders. V8s will always have that V8 sound. the closest you can probably get (or at least the most reasonable solution) would be high RPMs, an X pipe, and probably galss filled mufflers, definitely don't do a chamberd muffler like flow master. The cam you will need for your engine to breathe will at high RPMs will probably sound unmistakably like a V8 muscle car on the low end but smooth and high performance up high. if you really want that super car sound you might want try to find a V10. in the end a high revving V8 will probably sound closer to a NASCAR.
      Zach
      Jun 2006
      NW burbs IL
      Matt
      Long Beach, Ca
      The Wilson Motorsports buggy has an 8-1 collector:
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Jun 2009
      Quote Originally Posted by sik68 View Post
      Good article:
      Kinda cool. Never knew about that.
      Dan W
      1968 Plymouth Road Runner
      1962 Dodge Dart 440
      Nov 2009
      the dirty mitten
      Quote Originally Posted by Bow Tie 67 View Post
      Oooooo........wow that is exactly what I want.........must build.........
      Ok, after some quick searching I found that the 5.7 firing order is 1-8-4-3-6-5-7-2. From some more research, I should connect 1-4-6-7 and 8-3-5-2 rite? From there, should I put em into one pipe? After more thinking about my under car situation, I think that side exists are my best option. There will just not be much room to be had with the AWD setup. Im pretty sure Ill have have to do the dry sump ive been thinking about too
      Edit again: Or should I connect 1-6, 8-5, 4-7 and 3-2? Then merge 1-6 and 4-7, 8-5 and 3-2 and put em thru the cats and muffler then out?
      Steve
      Apr 2010
      Jersey Shore
      Maybe look into Dr. Gas feq mod muffler:
      http://www.youtube.com/watch?v=LSy_3nnsZdg#t=3m28s
      Those and the 180 degree headers might give you a pretty wicked sound
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Nov 2009
      the dirty mitten
      WOW! That was just a muffler that made a fox body 5.0 sound like that?!?
      Steve
      San Antonio, Tx
      on a small block i had in my '67 camaro i ran full 3" with an X-pipe to dynatech (mild steel version of borla) over the axle into hooker split resonator tips. it was a way different sound than i have ever heard from a small block and people offered to buy the exhaust all the time.
      Instagram: CamaroAJ
      Jan 2010
      Elk River, MN
      Good grief, those Freq Mod mufflers sound phenomenal...
      -matt
