Results 1 to 14 of 14
04-02-2011 #1
- Mar 2011
- 161
Need help with aerodynamic basics
I'm doing a non-pro touring build on my 78 lincoln mkv. The car will be receiving a warmed over 460 punched up to 471, 100 shot of spray, has 3 speed auto, 2:47 gears and is in need serious aerodynamic help. Even with the original stock 460 engine at high speeds air pressures build up under the car and lifts the body upwards in an on and off motion followed by a strong up movement that scares you into letting off the throttle. It's scary and I probably shouldn't drive my car that fast I know. I'm not going to stop and I need some info about front air splitters, as in roughly what shape and where should I mount it (near front bumper or towards front tires, car has feet of front overhang), if at all? Would I be better off fabricating panels under the car to improve airflow and not running a splitter? Are pretty much all splitters really just cosmetic? Is smoothing out the underside of the car to minimize drag substantially better than bolting on a front splitter?
04-03-2011 #2
- Aug 2004
- San Antonio, Tx
- 1,193
you need to get the air out from under the hood first and foremost. fender vents and hood vents sound like they are needed pretty bad.
Instagram: CamaroAJ
04-03-2011 #3
- Mar 2008
- 21
If lowering the car is an option, that will help as well.
I'm working on fender vents and considering a hood extractor myself.
04-03-2011 #4
- Mar 2011
- 161
Didn't realize fender vents can have such an impact. Luckily the car has cosmetics fender vents that can be made functional. What can I do to encourage air flow to the fender vents? Is any type of ducking advantageous, or is simply hacking into the inner side of the fender to open up the MkV's factory fender gills sufficient? I'll think I'll do the functional fender vents mod and a front air splitter (to deflect air not generate down-force) and feel what it does. In this car you can literally feel the poor under carriage aero effects. I really don't care about my drag coefficient as much as I want to mitigate the car's tendency to become an airfoil at speed. Thanks a bunch guys and I'll keep you posted on my progress once I begin.
04-04-2011 #5
